Fan noise after thick radiator install - Hardtuned.net
1 reply to this topic
#1 stockblues15
  • Car:JDM S15 Spec-R
Posted 02 December 2017 - 01:17 PM
Not sure if anyone else has noticed much more fan noise after installing a 52mm alloy radiator. I never used to notice any fan noise with the stock radiator. I think possibly the viscous clutch is getting to much heat as it is now physically closer to the radiator code, making it operate harder earlier. This happens even on cool days after 20 mins or so driving.
Engine is basically stock with Nismo thermostat and alloy china radiator (52mm triple core). Engine temps are fine (probably cooler than they should be for daily driving) and system has been bled.
I just want to know if this is a normal thing with an alloy rad replacement that I haven't seen mentioned before.
#2 6330
Posted 19 December 2017 - 12:17 PM
I would double check the clutch fan is mounted properly if you removed it when installing the new radiator.
The water temps would be running low because the combination of the oversized radiator and Nismo thermostat.
Personally I think the Nismo ones aren't needed.
