R33 drum assembly ... caliper disc options - Hardtuned.net
5 replies to this topic
#1 HUSTLA
  • Car:Nissan Silvia s13
Posted 07 December 2015 - 07:01 PM
Yes another brake upgrade question but couldn't find a anwser for this 1...
I have a complete r33 gtst rear drum assembly which will be adapted to s13 knuckles and retain 4stud hub.
Can I use r32/z32 calipers and rotors ?
#2 B00sted180
  • Car:180SX
Posted 07 December 2015 - 08:53 PM
S13 rear knuckle is the same as R32/33 Z32. I bolted my R33 brakes straight to my S13 knuckle. Just need to re drill your rotors to match the 4 stud.
#3 HUSTLA
Posted 08 December 2015 - 05:57 AM
Thanks but I want to know if the r33 drum assembly will work with either r32 or z32 calipers and rotors.
#4 Varvs
  • Car:97 180sx Type X
Posted 08 December 2015 - 11:31 AM
you would need calipers from a vehicle that uses the drum assembly.
From memory that means Z/R should be OK, S is not.
#5 B00sted180
  • Car:180SX
Posted 08 December 2015 - 02:05 PM
R32/33 Z32 rear drum assembly, discs and calipers are the same.
#6 HUSTLA
Posted 12 December 2015 - 07:34 PM
Thanks
