Radiator Coolant Flush & Replace - Hardtuned.net
  • This topic is locked This topic is locked
No replies to this topic
#1 Biggles
  • Car:S13 K
Posted 30 September 2006 - 11:15 PM
This is how to drain your old coolant, flush the system out completely and then replace the coolant.
This DIY was written using a 91 Nissan Silvia, but should be similar to most cars.
*Vehicle: 1991 Nissan Silvia - SR20DET
*Installers: David & Aaron (Hilarious Motorsport)
*Coolant used - Tecaloy 100+
*Tools: Jack, Jack Stands, Philips-head screwdriver, oil pan, hose, funnel
1. Jack the car up (we used a trolley jack to make this simpler; you can do it with a normal jack on each side though).
Attached Image: Silvia_Brakes_007__Medium_.jpg
2. Place jack stands under solid supports for the car, lower the jack and make sure the car sits solidly on the stands.
Attached Image: DSCF4886.JPG
3. Remove the radiator cap.
4. Place the oil pan under the radiator drain plug (this is located on the passenger side, on the bottom of the radiator).
Attached Image: DSCF4883.JPG
5. Remove the drain plug, and catch the coolant in the oil pan.
Attached Image: DSCF4893.JPG
6. Empty the coolant from the radiator bottle. You can either remove the bottle and empty it, or take the hose off the top of the radiator and feed it out under the car (gravity will then drain the water from the bottle). Once drained, replace.
7. Turn the car to “On” and set the air con to hot (maximum) and the fan speed to maximum as well.
Attached Image: DSCF4889.JPG
8. Loosen the hose clamp from the heater hose, and remove the hose. Be careful when removing this hose, as the pipe that it connects to, is usually plastic and can be easily broken.
Attached Image: DSCF4890.JPG
9. Place your hose, into the heater hose.
10. Turn on the hose with gradual pressure, so that water starts flowing from the drain plug but does not spurt out from the top of the radiator. Wait for clear water to flow out from the drain plug.
11. Put the hose into the other side of the heater hose and again wait for clear water to flow out from the drain plug.
12. Replace the heater hose.
13. Replace the drain plug.
Attached Image: DSCF4896.JPG
14. Fill the coolant overflow bottle, with the new coolant. (We used a Coke bottle with the bottom cut off as a funnel).
Attached Image: DSCF4909.JPG
15. Slowly fill the radiator with the new coolant, until it reaches the top.
16. Start the car, with the heater still on.
Attached Image: DSCF4899.JPG
17. The coolant will start to bubble as the air in the system escapes. Keep filling the coolant back up when it gets low.
18. Once the system stops bubbling, rev the car, and maintain a constant rpm (2,000) for a while. This will open the thermostat (when the car reaches temperature) and will also pump the coolant through the system, pushing the air out through the radiator. Make sure you keep topping it up as required.
Attached Image: DSCF4885.JPG
19. Once the system has stopped bubbling, replace the radiator cap.
20. Jack the car up.
21. Remove the jack stands.
22. Lower the car back onto the ground gently.
23. Take the car for a drive, and keep an eye on the temperature.
Finished!
