Garrett GT2871R s13 s14 s15 180sx turbo kit: turbo, manifold, dump, MLS gasket Hi-temp coat - Hardtuned.net
2 replies to this topic
#1 2qwk4u
Posted 20 February 2017 - 11:58 PM
Selling due to upgrade done 3000kms, comes with everything in pics can post or meet.
located in VIC.
$ 1,050 ono
0476 199 933
cheers
Simon
Attached Image: turbo-1.jpgAttached Image: turbo-2.jpgAttached Image: turbo-3.jpgAttached Image: turbo-4.jpgAttached Image: MLS-gasket.jpg
  • Bearing Type: Ball Bearing.
  • Cooling System: Oil & Water Cooled.
  • Turbine Housing: Internally Wastegated 0.64a/r
  • Base Flange: T25.
  • Exhaust Outlet Flange: 5 Bolt CA18DET / SR20DET style.
  • Actuator Pressure: Standard 14.7psi / 1 bar
  • Horsepower: 280-475hp.
  • Displacement: 1.8L - 3.0L.
  • Other Specifications:
  • The Turbine Wheel is cast from Inconnel material for extreme applications.
PRODUCT NOTES
  • The GT2871R will bolt directly onto the CA18DET/SR20DET factory exhaust manifold and dump pipe, however this comes with after market stainless dump and manifold.
DUMP PIPE
  • Made out of Stainless Steel Grade 304 with excellent flow and fitment
    The dump pipe will help to scavenge turbo exhaust gasses and help produce faster boost, more boost and more torque by reducing obstructions in the standard dump pipe.
    These are all hand ported to ensure smooth flow. 100% 304 stainless steel TIG welded for durability & strength.
    HI TEMP COATED
    The corrosion-resistant stainless steel material used in manufacturing this product is good with heat resistance up to the flange.
  • Made of High Quality T-304 Stainless Steel with steel flanges
  • All TIG Welded
  • O2 Sensor Bung
  • Hand Ported Internals
MANIFOLD
SR20DET Turbo Tubular Manifold
Made From 304 Top Grade Stainless Steel
Mandrel Bent, CNC Machined Flanges, TIG Welded
2.8mm Thick Pipes
42mm Diameter Pipes
1/2" Thick Flanges For Solid Support
HI TEMP COATED
Ported & Polished
SHOT PEENED STAINLESS STEEL after welding
Turbo Exhaust Manifold Gasket MLS SR20DET Nissan 200sx Silvia 180sx S14 S15
MLS stainless steel gasket is designed for the perfect seal every time. Multi precision cut stainless steel shims are joined via brass rivets resulting in an invisible gasket. Multi layer gaskets can still give a successful seal even on slightly warped faces and can be reused, unlike their fibre counterparts.
#2 2qwk4u
Posted 22 February 2017 - 11:46 AM
also comes with genuine z32afm
#3 2qwk4u
Posted 14 March 2017 - 10:47 PM
SOLD
