S13 sr20det problems! - Hardtuned.net - Page 2
37 replies to this topic
#31 tomtom141
Posted 02 August 2017 - 11:52 AM
I marked the cas and reset it there once I had move it.
What could cause the fuEl pressure to be low? I have put 2 new walbro pumps in her. Both working perfectly. And I've replaced my fuel filter with the bog stock fuel filter and the larger z32 filter. I don't know what else to change in the fuEl system
#32 adm15
  • Car:s15
Posted 02 August 2017 - 03:01 PM
Fpr
#33 tolkaNo
  • Car:Nissan 180SX
Posted 02 August 2017 - 05:05 PM
Do you have that gauge connected to your fuel return line? If so that's why it reads low, its not under pressure
#34 tomtom141
Posted 02 August 2017 - 06:27 PM
It was rigged up between the fuel filter and the fuel rail. Not after the fpr
#35 tolkaNo
  • Car:Nissan 180SX
Posted 02 August 2017 - 06:33 PM
Did you check your voltage at the fuel pump? It's not getting like 8v's or something is it?
#36 pur40m
Posted 02 August 2017 - 06:42 PM
Well you found your problem you only got 2bar fuel pressure did you remove the vaccum line of the reg when you tested it?
Either theres a leak somewhere or your reg is faulty
#37 tomtom141
Posted 02 August 2017 - 07:17 PM
I literally 10 mins ago clamped off the return fuel line and tried to start it. No difference. So I got a volt meter out and tested the pump. 1 pin had 12 volt and 1 pin had 6.3 volts which I'm guessing is a signal wire. So guessing it's getting all the voltage it needs.
Didn't test the fpr with the vac line off but I can give it a go tomorrow.
With the vac line off it should fall a few psi yes? But if it doesn't your suggesting its a vac issue and if it does fall it should be a fpr problem
#38 stockblues15
  • Car:JDM S15 Spec-R
Posted 05 August 2017 - 11:41 AM
Sounds like a bad earth to your fuel pump. 6.3 volts isn't good (unless you measured the fuel gauge signal by mistake). Bad earth's to the fuel pump can be an issue.
Edit: The earth to the pump goes through a relay that is controlled by the ECU. Maybe you have a bad relay or bad wiring.
Edited by stockblues15, 05 August 2017 - 11:55 AM.
