s15 6spd and brass button clutch? - Hardtuned.net
11 replies to this topic
#1 mexr69
  • Car:type x, ca sil80
Posted 17 April 2017 - 02:43 PM
Hi all just wondering if a brass button clutch is OK for the 6spd trans?
anyone running one ??? Thanks.
#2 Kirksil13
Posted 17 April 2017 - 03:33 PM
Is it a dedicated track car or does it get driven daily. If daily driver id recommend exedy hd organic or npc 10in organic depending on your power.
#3 mexr69
Posted 17 April 2017 - 05:07 PM
Will be a weekender mate. planning on 200-220 rwkw.
hope the brass button is OK for a weekender and doesnt KILL my 6spd.
#4 andhey
Posted 17 April 2017 - 06:19 PM
exedy HD will be better suited for your power goals and a LOT more comfortable to drive
#5 pmod
  • Car:Fruity 180sx
Posted 18 April 2017 - 03:35 PM
Don't do it to yourself man. Get an organic clutch built to your clamping specifications and actually enjoy driving the car. Mine runs a quality sprung 3-puck, so it's far more forgiving than a brass button, and even that can be a pain in the ass on the street with all the shuddering and hard engagement at low RPM. If I could do it all again, I'd just cough up the coin for an NPC organic, like everyone recommends.
#6 pur40m
Posted 19 April 2017 - 06:45 AM
Dont go a puck or brass button clutch on a s15 6spd if you want it to last
You will blow 3rd gear if you drive it hard as it too harsh on the box
Organic will be easier on the box
#7 mexr69
Posted 19 April 2017 - 09:13 AM
bought a car with a brass button in it -,- i guess ill take it easy and get some coin together i msg NPC solid conversion flywheel and heavy duty 10” organic clutch Cost $1254inc gst + freight but may aswell go the s14 5spd... how reliable are the 6spds?
#8 pmod
  • Car:Fruity 180sx
Posted 19 April 2017 - 10:32 AM
The 6 speeds seem pretty good if you aren't clutch kicking them with big power, or just being a tool. Most times they blow it's from a rough clutch, drifting or making huge power (220kw is not huge). I do however have a question; are you looking at the clutch that's attached to the 6 speed gearbox and assuming it's a brass button based on the lack of springs? It might be worth mentioning that the S15 6-speed dual-mass flywheel runs a clutch driven plate that's unsprung, as the flywheel acts as the engagment spring. Courtesy of Google Images:
If by brass button you meant a 3-5 puck driven plate, presumably unsprung for use with the stock dual-mass flywheel, then the previous advice stands. Shops sell them, but I wouldn't go for that myself.
#9 mexr69
Posted 19 April 2017 - 05:18 PM
unsure mate, previous owner said that it has a brass button clutch and has all the paper work for it also. no idea to be honest with you pal.
thanks to that i guess ill just keep the brass button in and hope for the best lol, then do a s14 5spd conversion
#10 Tom Tucker
Posted 21 April 2017 - 06:07 AM
6 sp is a sweet box. Mine was rock solid with NPC organic (I had 345rwkw without it breaking)
The ratios are great. Installing a brass button is molestation. And then installing a 5 sp is going backwards.
Arse clowns who complain about it breaking drive like idiots and should have auto only licences
#11 Scotties15
  • Car:S15 200sx
Posted 22 April 2017 - 01:11 PM
Well said Tom.
I'll add what iv find online over the years....
Drifting and the constant hammering of the gearbox loading and unloading in say 3rd kills them. It's that pressure that hammers off the circlip on end of 4th.
Iv never experienced any problems with it in the order of 250rwkw.
And yeah I do agree, I love the ratios in it.
A nice organic clutch will hold power all day and be nicer on the driveline
#12 S15 sxytime
  • Car:S15 GT spec R
Posted 22 April 2017 - 04:25 PM
Totally agree, great ratios for driving through the hills, it's only abuse that breaks gearboxes. You can still drive a car hard with power without blowing a gearbox, if you break an S15 6 speed you will probably eventually break the S14 gearbox anyway because of abuse. Brass button clutches are shit anyway there are better ways to go these days.
