Budget racer surge tank - Hardtuned.net
1 reply to this topic
#1 davidg2152
  • Car:S13 SR20DET
Posted 12 February 2017 - 09:49 AM
Commencing surge tank research.
After some simple insurance for the banger race car. I have a walbro intank and want to add a surge that I can use in hillclimbs etc (cams compliant). Nothing fancy just cheap insurance.
Any advice of what works is appreciated.
Dave
#2 The Big Fist
  • Car:s15
Posted 13 February 2017 - 08:59 AM
Ebay surge tank, Bosch 044 external pump and filter if not running E85.
6mm perspex box if sitting in boot.
If running E85 It's a bit trickier to get the right surge tank.
Pump wise you can run an 044 but they are only rated for 500 hours. Which is a fair bit of time in the car realistically.
Proflow do an 044 knockoff that is apparently E85 compatible.
I'd probably look at something like a deatschwerks or walbro inlines over the proflow though.
Just cost it all up beforehand with fittings etc. You might find you arent all that far off a taarks surge tank with in tank walbros.
I am at the same position as you but can't decide which way to go !
  • Google
