R200 diff identification - Hardtuned.net
R200 diff R200
9 replies to this topic
#1 frenchy
  • Car:Madaz FC3S Rx7
Posted 05 August 2017 - 04:22 PM
Hey guys,
Anyone ID these diffs for me?? Have searched but can't find. One is stamped UN and the other A5.
UN one has chunky cooling fins on the rear and viscous lsd sticker. Also slightly different mounts than the A5.
Thanks
#2 frenchy
Posted 05 August 2017 - 04:24 PM
Can't upload photos from my phone..
Edited by frenchy, 05 August 2017 - 04:27 PM.
#3 Danie l
Posted 14 August 2017 - 08:13 AM
r200 = 200mm accross, 180 = 180. S13 reear aluminium hats have the fins, seen on r180s might exist for r200 too though
#4 frenchy
Posted 14 August 2017 - 07:50 PM
Thanks.
They're r200's but from what cars is what I'm interested in. New to nissans and just trying to piece things all together for interchangeability. Surprised I havnt been able to find much info on the stamps..
This forum doesn't get the same sort of traffic it used to when I was active many years ago. is there a Facebook page or something?
#5 Wizard
  • Car:Moneypit
Posted 15 August 2017 - 06:11 AM
You'll do much better with a picture than stamps
#6 frenchy
Posted 15 August 2017 - 07:16 AM
Your right. For some reason I can't upload pics. It fails.
#7 frenchy
Posted 15 August 2017 - 07:19 AM
Got it. Had to compress iPhone photo file size
  • Attached Image: IMG_8615.PNG
#8 (Locky)
  • Car:kouki s14
Posted 15 August 2017 - 08:02 AM
s14/15/r33 bushed front mounts, 2 stud rear hat
s13 solid front mount, 4 stud rear cover
covers can be swapped over, just have to use the corresponding bolts for what front mount the diff has
s13 came both 5 and 6 bolt half shafts, I think s14/15 were all 6 bolt, R33 5 bolt
front is probably r33 with a s13 rear cover finding out ratio will give more info
the back one is s13, 4.08 is also stock s13 ratio,
#9 (Locky)
  • Car:kouki s14
Posted 15 August 2017 - 08:04 AM
Oh and 4 bolt rear covers that drop down more and look like have larger cooling fins are to give clearance for Hicas ( or lock bar) so if have a hicas rear need that cover
#10 frenchy
Posted 15 August 2017 - 03:52 PM
Thanks champ. Will open them up to check centres/ratios
