SeaNo180
Yeah I Chea told me u maxed out the 3 bar map sensor
Chea put a 5 bar map sensor in mine so I shouldn't max that out
Won't be getting it tuned for a while still need to rewire the car sad.gif I'm also going to a custom cam shaft
Aha So u running 29psi? Sounds like ur running 45+ if your maxing out a 3 bar map sensor wink.gif lol
yeh maxed at 29psi. the 5 bar is the way to go gives u plenty of head room, more then enough for the street anyways.
yeh i know lol, these precision turbos love the boost. the more u put through them the happier they get.
Has anyone got any results for Tomei Arms M7790/m8270 on a sr?
I would be interested to see 2L block results
Make and model: Nissan S13 Silvia
Size of engine: 1.8L CA18DET
Modifications to the car: 20 thou oversize forged acl pistons, acl race bearings, acl metal head gasket, GTR 444cc injectors, RB25DET AFM, 600x300 front mount, 3 inch turbo back exhaust
Type of turbo: S15 t28 Ball Bearing
Trim of turbo:
Rear Exhaust housing:
When does vehicle begin boost: 3000ish
When does vehicle reach full boost and what PSI: 4500ish on 13 pound
Does the vehicle have Cams? if so; CA18DET exhaust cam also on intake (same as intake cam just 5 degrees advanced)
What brand:
What lift/duration etc:
Max power achieve at what boost: 165.3rwkw on 13psi
also ran a touch over 180kw on 17psi but that aint good for turbos with ceramic internals
w00t2.gif holy fecking shit bricks! awesomo powaHHH!!
Make and model: 2001 ADM Nissan S15
Size of engine: sr20DET
Modifications to the car: forged motor, CP Pistons, Crower rods, Ported head oversized valves the works
Type of turbo: Precision 6265 twin scroll
Trim of turbo: 76mm trim
Rear Exhaust housing: A/R .70, Divided T4
When does vehicle begin boost: 3500rpm
When does vehicle reach full boost and what PSI: 5000rpm @29psi
Does the vehicle have Cams? if so; yes
What brand: Brian Crower 264 in 272 ex
What lift/duration etc: 12.06mm
Max power achieve at what boost: 407rwkw @29psi
http://www.youtube.c...u/3/8xRHRRHZSuI
More to come!!
Is a 1.06 rear housing too big for a sr23 for around 350ish?
Make and model: 1997 Type X Blacktop SR20DET
Size of engine: 2.0L
Modifications to the car: Forged, Port/Polished Head, 740cc Inj, Poncams + Springs, HKS GT-RS, Jap Manifold
Type of turbo: HKS GT-RS
Trim of turbo: 52
Rear Exhaust housing: 0.64
Boost: 1.0 bar
When does vehicle begin boost: 2700rpm
When does vehicle reach full boost and what PSI: 3400
Does the vehicle have Cams? if so; Yes
What brand: Tomei
What lift/duration etc: Poncams 256in/256ex
337rwhp @ 1bar, hub dyno.
can you please post your dyno printout
Size of engine: CA18
Modifications to the car: Stock CA18, FMIC, Microtech LT8
Type of turbo: T61
Trim of turbo:
Rear Exhaust housing: T4 .68
When does vehicle begin boost: 4000
When does vehicle reach full boost and what PSI: 4500 = 12psi
Does the vehicle have Cams? if so; Stock
What brand: N/A
What lift/duration etc: N/A
Max power achieve at what boost: 183kw@12psi (Maxed out stock 370cc injectors at 6000rpm)
Make and model:Nissan R31 skyline
Size of engine: 3Lt rb30det
Modifications to the car: 25box hks twinplate 040 pump 550cc injectors
Type of turbo:gt3540r
Trim of turbo: .70
Rear Exhaust housing: .82
When does vehicle begin boost: 1800rpm
When does vehicle reach full boost and what PSI: 3000rpm
Does the vehicle have Cams? No but using NEO head... so stock NEO cams
Max power achieve at what boost:370 rwkw@15psi @ 7000rpm maxed out injectors
Make and model: 180sx
Modifications to the car: Forged ACL race series kit, Ported/Polished Head, 850cc Inj, Custom intake plenum, 90mm throttle body, Malpassi FPR, Power FC with Microtech Lt-10s (piggy backed) yea i know dont ask, Greddy cooler, 3.5in catback, Splitfire coil packs
Type of turbo: t25g (stock) for now
Boost: 10psi
When does vehicle begin boost: Nearly on Idle.
When does vehicle reach full boost and what PSI: about 2500rpm
180rwkw
Make and model: 1995 180sx
Modifications to the car: Stock bottem end, Poncams, Tomei Valve Springs, Tomei 740cc injectors, modified stock airbox with blitz filter, Greddy spec LS FMIC, walbro pump, z32 AFM, 3" turbo back exhaust, magnaflow cat, Blitz ID3 EBC
Type of turbo: Garrett 2871R, 52 Trim, 0.64 exhaust housing
Boost: 21psi
When does vehicle begin boost: 2500
When does vehicle reach full boost and what PSI: 3700rpm
Max power achieve at what boost: 242kw@21psi
Make and model: s13 SR20DET redtop
Modifications to the car: FMIC, 3" exhaust, 850 injectors, z32, hks gt-ss turbo, hard intake, fuel pump
Type of turbo: HKS GT-SS
When does vehicle begin boost: 2000
When does vehicle reach full boost and what PSI: 3200? = 16psi
Does the vehicle have Cams? NO
Max power achieve at what boost: 199.1 @ 16 PSI and 507.5nm
Make and model: Jap Spec S15
Size of engine: SR20DET
Modifications to the car: Full Exhaust, FMIC, Boost Controller, Walbro fuel pump
Type of turbo: Stock T28 BB
Trim of turbo:
When does vehicle reach full boost and what PSI: 3900
Does the vehicle have Cams? if so; nope
What brand:
175RWKW at 15psi
Edited by Manez
Make and model: Jap Spec S13
- Custom fuel rail.- 6Boost manifold.
- Custom 3" dump
- Custom 3" full exhaust, no cats, no mufflers
- Japanese brand intercooler + piping.
- Z32 AFM.
- Tial 44mm external gate + screamer.
- K&N pod filter.
- Manual boost 'T'.
- Wallbro intank fuel pump.
- Custom fuel feeder system in engine bay
Type of turbo: GT35R
Trim of turbo:
Rear Exhaust housing: 0.63
When does vehicle reach full boost and what PSI: 4600
Does the vehicle have Cams? if so; No
What brand:
Max power achieve at what boost: 354rwhp @ 18psi
Power:
-354HP @18psi on E85.
Tuner:
- Andy Stevens @ Hyperdrive Motorsport WA.
Edited by Torquen
Make and model: ADM Spec S15
-Greddy FMIC
-HKS Front Pipe
-HKS Silent Cat Back
-Decat Pipe
-Apexi Pod Fitler
-Power FC L-Detro
-Manual boost 'T'.
-Wallbro intank fuel pump.
Type of turbo: AMD Bush Bearing T28
When does vehicle begin boost: tba
When does vehicle reach full boost and what PSI: tba
Does the vehicle have Cams? if so; HKS Stage 1 264/264
Max power achieve at what boost: 255rwhp @ 16psi
Ovaboost Dyno
Tuner
-Mick Monroe
Make and model: 1992 180sx 128km
Modifications to the car: Stock bottem end, Poncams, BC Valve Springs, Tomei 740cc injectors, tomei rocker arm stoppers, cobalt rocker arms, Tomei expreme dump pipe + 3 inch front and apexi cat back,highflow cat, walbro pump, z32 AFM, nistune tuned by ECC, metal intake pipe, Greddy Profec B Spec 2, unboxed pod filter, Blitz DD BOV, FMIC.
Type of turbo: Tomei ARMS M7960
Boost:Low boost 14psi, High boost 18psi
When does vehicle reach full boost and what PSI: 3700rpm - 3900rpm
Max power achieve at what boost: 206.8 kwatw on 14psi
221.7 kwatw on 18psi
227.8 kwatw on 19.5psi
- Custom 3" dump
- Z32 AFM.
- K&N pod filter.
- Manual boost 'T'.
Trim of turbo:
What brand:
Power:
Tuner:
thats surely a bit low isnt it?
oh wait sorry no cams...just saw...hows the lag with no cams on that?
Edited by gulrez
Make and model: Nissan 180sx
Size of engine: 2L
Modifications to the car: fuel pump, bay mounted cooler, 3" turbo back exhaust, gktech manifold etc
Type of turbo: hypergear
Trim of turbo: same as a 3076r apparantly
Rear Exhaust housing: 0.86 i think
When does vehicle begin boost: havent looked closely but around 3200?
When does vehicle reach full boost and what PSI: again havent looked but guessing 4200?
What brand: BC Step 3 272
What lift/duration etc: 272 12.5mm
Max power achieve at what boost: 290.1kw @ 24psi
nice :) spewing about that 10 kw though eh? i had the same lol i missed out but like 7.5kw :(
My old drift S13.
Tuned it last night for the new owner.
Full NITTO build SR20. Low mount 3071r t28 flange. New 1200cc highflowed injectors. Drift suspension etc. Tomei solid top end.
22.9psi 307.7kw max run. 306.6kw on a higher load.
Before and after Dyno sheet
Edited by DVS JEZ
- Custom 3" dump
- Z32 AFM.
- K&N pod filter.
- Manual boost 'T'.
Trim of turbo:
What brand:
Power:
Tuner:
Not too bad really, boost by 3100, full boost by 4700.
Shes a bit laggy atm but hopefuly some cams and e85 + new tune will fix that ;)
Make and model: 1991 s13
Size of engine: 2l sr20det red top
Modifications to the car: Kings Rod and Main bearings. Clearance checked and mirco polished crank. ACL Race Series performaqnce MLS head gasket, new head bolts. Reconditioned head, back cut valves for extra flow, tomei arms m7960 turbo, 3" exhaust, power 8500cc injectors, 040 fuel pump, tomei expreme mainifold, sard FF regulator and a p1000 haltech
Type of turbo: Tomei Arms m7960
When does vehicle begin boost: 2800
When does vehicle reach full boost and what PSI: 5500 approx 20psi
Does the vehicle have Cams? if so; NO
Max power achieve at what boost: 252atw kw
Make and model: SR
Modifications to the car: Forged, Port/Polished Head, 650cc Inj, .5mm oversize valves, twin valve springs, 2871, standard manifold
Type of turbo: 2871
Trim of turbo: 52
Boost: 20.5psi dropping down to ~17psi
When does vehicle begin boost: 80km/h 4th gear (on the dyno, have not had a chance to drive yet)
When does vehicle reach full boost and what PSI: 112km/h 4th gear
What brand: Tomei
What lift/duration etc: 260* 12mm
233.7kw dyno dynamics @ Jazmac SA
Wastegate actuator wouldnt hold 20+psi, power tapers off after 6.1k RPM.
Edited by cheney
Make and model:180sx
Size of engine:sr20det non VCt
Modifications to the car:740cc injectors poncams z32 afm fmic 3inch tbe deatchwerks pump eflex e85 std motor
Type of turbo: kando td05h18g
Trim of turbo: ???
Rear Exhaust housing: 8cm
When does vehicle begin boost: 2800rpm
When does vehicle reach full boost and what PSI: 4000rpm 20psi
Does the vehicle have Cams? Yes
What brand: tomei poncams
What lift/duration etc: 256 11.5mm lift
Max power achieve At what boost: made 260rwkw on 23psi but was running lean due to 740cc injectors on e85 so wound it back to 20psi still makeing 253rwkw
Would love to see what it makes on 25psi but need atleast some 1000cc injectors
Edited by pur40m
Make and model: Nissan 200SX, S14A
Size of engine: 1998cc
Modifications to the car: Nistune, Z32 AFM, E85, SARD 850cc injectors, Aeromotive 340 Stealth pump, custom 3mm stainless high mount manifold, 3inch exhaust from the turbo, BC cams, Blitz boost controller, China intercooler.
Type of turbo: Borg Warner 6258
Trim of turbo: Damn good question that, 49.6mm inducer, 62mm exducer, make of that what you will.
Rear Exhaust housing: .64 (T2)
When does vehicle begin boost: 2,000-2,400 (4th gear, road test).
When does vehicle reach full boost and what PSI: 3,400 (4th gear, road test), 17psi, drops to 15 (vac leak).
What lift/duration etc: 262°, 12.06mm
Max power achieve at what boost: 261 @15psi on a mainline dyno, will be re checked when I've located and stopped the vac leak.
It's pretty spastic. Feels like it wants to constantly be on boost. 80km/h in 5th, all I need to do is breath on the throttle and I've got positive pressure.
Edited by scandyflick
Vehicle: 1991 Nissan Silvia S13
Engine: CA18DET
Modifications: Z32 AFM, Pod, FMIC, Oil Cooler, SS Manifold, Custom Dump/screamer/front pipe, decat & BIG exhaust, walbro + 044 external setup, 440cc injectors, nistune computer.
Turbo: S15 T28BB
Full Boost: 3500 approx @ 15psi
Cams: No.
Final Power Figure: 210.5rwkw @ 15psi / 513.2nm of torque (getting a retune with revised fuel setup & more boost)
Edited by 1991_SHOW_CA18DET
