loz
Prototype Pics and Vids ONLY - No Discussion
Toyota FT-HS
Boasting a powerful V6 3.5L engine, the FT-HS is coupled with Toyota's Hybrid Synergy Drive® to produce a target power output of approximately 400 horsepower and a projected zero-to-60 acceleration in the four-second range. At a mid-priced market position, the FT-HS would be a true “attainable exotic” with 21st-century performance.
A sculpted front and rear remove mass around key functional components, while the roof has a distinctive scooped-out section designed to reduce aerodynamic drag and provide head room at the key areas.
The FT-HS's interior features create a dedicated driver's cockpit that includes a cross-car instrument panel structure and delta-wing driver pod. An integrated instrument panel surrounds the driver, creating an enclosed pod effect. Armrests flow seamlessly into the door and surrounding interior. Seating is optimized for a lightweight appearance and function: The seating accommodates four and then converts to a two-seater when the roof retracts.
C|net review:
Concept Pics:
