richo79
Nissan S14 Zenki '95 325rwkws Flex fuel Part out, Wrecking vehicle and garage clean out
25000kms on engine and parts - 325rwkws @24psi Flex Fuel
Power Tune forged short block (500kws) LONG MOTOR $5000
· Bore and hone block
· Deck block
· CP forged pistons and rings 86.5mm
· BC conrods ARP2000
· ACL Race Series engine bearings (main, rod and thrust)
· ARP main studs
· OEM Water pump assembly
· OEM Oil pump assembly
· OEM timing chain kit
· OEM rear main seal
· OEM Front crank seals
· Tomei sump
· Tomei head gasket 87mm 1.5mm
· Tomei rocker cover
· Oil adapter block – remote oil filter
Power Tune ported head package (500kws)
· Crack test
· Pressure test
· Surface grind
· Acid clean
· Custom valve seats
· New valve guides
· New valve stem seals
· Hand port and polish
· Oversized valves
· Match ported to exhaust gasket
· Match porting to inlet manifold
· BC single springs and titanium retainers
· BC intake camshaft 264
· BC exhaust camshaft 272
· BC intake valves +1mm
· BC exhaust valves +1mm
· BC adjustable cam gear – exhaust
· Tomei adjustable cam gear – intake
· ARP head studs
· Rocker stopper kit
RB25 gearbox cut and shut, DCS 2200LB twin plate clutch(needs rebuild), dogleg sort throw shifter, Kreative Enterprises custom tail shaft $2000
Power Tune Twin In-tank fuel pump kit 1000HP $1000
· 2x Walbro 500HP 225L/HR
· Braided lines and fittings front to rear -6
· Earls inline filters -6
Cusco 2way 4.08. $600
Haltech Platinum Pro S15 $1200
Haltech Air Temp sensor $30
Haltech 3 Bar MAP sensor $80
Haltech boost control solenoid $80
Haltech I/O 12 channel expander box $400
S14 to S15 adapter harness $100
Ethanol sensor – To run on E85 or 98 unleaded and any combination of the two $220
Garrett 3076 T3 .63 BB Turbo $900
6 Boost manifold $600
Turbosmart 38mm Wastegate $350
Turbosmart Raceport BOV $250
Turbo smart FPR800 $200
JUN type Inlet manifold, 870cc Siemens injectors, BMI top feed fuel rail (twin entry) $700
Black speedflow fittings throughout w/ black lightweight braid $Various
Race Solutions – Intake pipe, Air box, Intercooler piping, Power steering reservoir, Oil catch can and Overflow bottle. All powder coated black $Various
Odyssey Battery PC1200 with bracket mounted in boot $250
MR Racks rebuilt power steering rack including rechroming $350
Holford Motors – HFM Castor, Toe and Traction Rods $250
Ikeya Formula rear upper arms (camber) $200
Immaculate S15 front and rear seats $500
Navan front bar $500
Navan side skirts and rear pods – not fitted $250 and $150
JDM rear bar $300
30mm rear over fenders – not fitted. As new gel coat $200
Siebon Carbon fibre door panels, 1 piece OEM style – not fitted $600
Powertune topfeed fuel rail with 2000cc injectors – not fitted $600
Nolathane rear subframe bushes in subframe
RDA slotted, dimpled and gold passivated rotors
Heaps more stock parts
All located Penrith NSW. Photos available on request. Currently all on vehicle unless specified. Car is NOT running at present
Edited by richo79
what brand are the overs?
30mm - M Sports. Bought from Top Secret Imports Blacktown
Edited by richo79
whats the condition of the cusco 2way 4.08 diff?
Spot on. Works as supposed to. Tight as.
All parts are tip top, except clutch requiring rebuild.
Can you put some pics of the race solutions stuff please
I wanna see pics !
Pics up
Oil cooler and GTR rear subframe SOLD pending inspection
Ayyyye richo sad to see your selling your gear I know it is for the better
Im interested in a few things you have
Gearbox etc and diff
Possibly your complete haltech gear and possible bare engine
Oil cooler and battery sold
I can sort you out the for the lot ive have told you so far bro
Gl with the sale bro
alot of goodies at cant beat pprices.these thread only come once a blue moon
Hey Antz, thanks mate.
Have had some interest in Haltech stuff and gearbox. Nothing solid yet.
Engine is yours, I will throw in extra goodies too.
Thanks man, see you soon.
Edited by richo79
Battery SOLD
Edited by richo79
Let me know if the complete gtr subframe sale falls through. Wish I had of seen this earlier :(
Edited by gomanji
Will do
Steering rack SOLD
Haltech I/O 12 channel expander box SOLD
Edited by richo79
Haltech Platinum Pro S15 SOLD
Haltech Air Temp sensor SOLD
Haltech 3 Bar MAP sensor SOLD
Haltech boost control solenoid SOLD
Heaps of action over the long weekend, check original post for updates.
Unsure if made clear.... WHOLE CAR WRECKING/ FOR SALE
Edited by richo79
