dose me
S15 ABS light on and no speedometer
Right so story goes,
I was driving the car normally for about 20 mins, parked for 2 hours came back and ABS light was on and had no speedo...
now have been doing some digging thru the forums and talking to a few people...
Some background information:
ADM S15 2000 model spec r
high mount turbo if that makes any difference even tho its a fair distance away from ABS unit
I have check all fuses twice (engine bay and kick panel inside car)
Checked diff all sensors connected and undamaged
what other info can you guys give me?
anything i have missed or can do?
any info would be appreciated
regards George
The diff speed sensor may not look damaged but it's an electrical device that can fail.
If you have checked all fuses then swap the sensor with a known working one and go from there.
(Edit:
Before swapping the sensor you can check the power to and from the sensor with a multimeter)
Edited by fyjosh
