mill-180
RB 5 puck clutch, R32 gtst vertex kit, RB FS5W71C gearbox, TE37 style rims, Nismo muffler w/valve, R33/34 manual trans crossmember, 180sx front bar brackets
Hi, I need to clear some items I have sitting around the house
Vertex copy r32 gtst full body kit. Front and sides are drift condition. Hole cut out in side skirt for a side exit exhaust. Front bar requires fibreglassing. Looks to be AH3 red. SOLD
R31/VL rb30e gearbox. FS5W71C. I never used it so i dont know the condition of the gears or synchros. They all slot in otherwise. I recommend a new input shaft bearing before use as it feels a little tired.
For those that dont know, the rear housing of this box is shorter than the s13 boxes which means it should be good for an ae86/ke sr/ca conversion. Bellhousings are all interchangeable with ca/sr 5 speed. Comes with shifter, all sensors and bearing carrier. $200
sr20 180sx front bar brackets. This allows you to bolt your bumper onto the guards nice and flush. Comes with a random headlight bracket $40
5 puck exedy unsprung clutch and pressure plate suit rb20/25. Still useable. My Verniers are stuffed so i cant accurately measure thickness but it definitely still has a useable amount. $150
R34 gtr nismo oval muffler with a factory butterfly valve. Valve is seized up, needs a good hit of wd40. Overall good cond otherwise. $50
R33/34 manual trans crossmember and mount. Mount not pictured but is sitting in my garage somewhere. Good nick. $40
Set of 18x7 +40 volk te37 copies. 2 are cracked at the lip but still hold air lol. Tyres are shot. $100
Stock s13 front shocks and springs $30
Located in western Sydney, Fairfield area.
Will post anything at buyers expense.
PM or TXT 04017 555 one two
Edited by miller.k
