Voyz180
car running shit after new tank of fuel, is there anything i can do.
hey
so my car was running fine for a drive before i went to get petrol and on the way there, but after i filled up a whole tank of bp ultimate the car started to run real funny. the exhause note has changed and sounds like its purring more so like real slight popping almost sounds good but not. it also has f**k all power.
i even thought it could be running on 3 cylinders but i checked all my spark plugs when i got home and they all look sweet. will try coilpacks tommorow.
now i cant be sure its the fuel because ive never had a bad fuel caused problem before but its looking that way.
is there anything i can do like go complain and get me money back becuase i really cant be f**ked draining the tank wasting 70$ worth of fuel.
f**k BP this has given me the shits.
would chuckin in some octane booster help? i thought it was weird they had 80% of there pumps closed.
is there anything else it could be?
180sx sr20det with powerfc 220kw
Edited by Voyz180
That's weird they had 80% of their pumps closed, you should definitely talk to them about it and if it's a bad batch of fuel there would be more people having issues as well
I knew someone years ago who worked in a servo and if their fuel was deemed as contaminated or faulty they had to cover the costs of getting fuel tank drained etc
went to the servo and the guy said if i can prove the fuel was the cause then they could do something
Just from what you've said it sorta sounds like it's going into limp mode, doesnt necessarily mean it's bad fuel, maybe shit got stirred up in the tank and blocked the fuel filter or some other coincendence but check back with the station tomorrow and see if they've had anymore complaints.
A mates car did this too. He seemed to have gotten the last of the fuel stored in the servos tank. Pulled his fuel pump out and we had rocks and sand covering the pump intake sock. It's easy enough to pull the cradle and have a look man
Da f**k is limp mode?
Like a safety mode if something f**ks out it does shit like cut cylinders and won't rev past 3000 rpm to limit damage to the engine and so you can "limp" home. Most cars have it
thanks guys but it wasnt the fuel, one of my connectors on a coilpack is f**kd which came loose and caused the shit running issues.
all good now.
cheers
It's a feature all your tunes should have :P
Chew on some cock please :)
Do you mean to say you'd like him to get some Red Rooster?
no, i would like him to chew on my penis :) He knows he wants to, there's no denying it.
