HUSTLA
R33 drum assembly ... caliper disc options
Yes another brake upgrade question but couldn't find a anwser for this 1...
I have a complete r33 gtst rear drum assembly which will be adapted to s13 knuckles and retain 4stud hub.
Can I use r32/z32 calipers and rotors ?
S13 rear knuckle is the same as R32/33 Z32. I bolted my R33 brakes straight to my S13 knuckle. Just need to re drill your rotors to match the 4 stud.
Thanks but I want to know if the r33 drum assembly will work with either r32 or z32 calipers and rotors.
you would need calipers from a vehicle that uses the drum assembly.
From memory that means Z/R should be OK, S is not.
