Neptune Harrod
SR20DET idling/bogging issues HELP
Recently swapped a sr20det into my s13 doing a de to det conversion car starts up fairly quick and idles and it goes low then almost stalls then going up being low again then again same almost stalls. And if I give it a tap on the accelerator it dies.
Note. I have played with the cas. And if I move the cas elsewhere it struggles to turn on at all or if it does turns on for a bit then dies
HELP
CHEERS
rest the CAS as per the workshop manual. pull the rocker cover off. and you really hsould have noted the original porisiton of it.
you will also need to know how to time it.
checked for blown intercooler hoses / rags in the intake.
what your describing will also happen if you got a blown intercooler silicone hose or soemthing.
then again it could be anything. try looking for other things, and reset cas to stock standard
afm plugged in?
checked all cooler pipes?
checked for rags in pipese.
checked fuel filter.
checked injectors, fuel pump etc.
checked earthing.
dont have any vacuum lines not plugged back in?
Make sure it's the turbo AFM and not the DE AFM.
