Kieran O'Connor
Egi Fuel Pump Relay problem HELP!
So basically my problem is my fuel pump keeps cutting in and out randomly, iv checked my fuse which is all good and iv also swapped my relays so i know the relay isn't the problem either
i can get the car running by bypassing relay number 2 and 5 and my fuel pump stays on but not 2 and 3 which everybody on google says to do and works for them
on my relay number 3 and 5 have a break indicated on the relay which Leeds me to the question of does number 3 need a constant power to transfer power to number 5 when the relay connects that circuit?
Iv checked voltage from the pin sockets on my relay socket
1 - constant 12v with ignition on (ecu power?)
2 - constant 12v with ignition on
3 - nothing with/without ignition on
4 - nothing with/without ignition on (power wire to fuel pump)
all sockets have an earth apart from 3
