Guest Dragi
sr20de full gasket kits
Easy one to answer:
1. Yes, FRSport is a legit site and I have bought from them before.
2. FRSport is a North American site, not an Australian site. Look at their phone number mate.
3. Googling your exact phrase "SR20 gasket kit" returns Taarks (a.k.a EFI Solutions) and JustJap as the top results, so I have no idea wtf you tried lol:
https://www.efisolutions.com.au/engine-gasket-kit-s13-180sx-sr20det-redtop
http://justjap.com/genuine-nissan-engine-vrs-gasket-kit-nissan-s13.html
4. Taarks and JustJap are legit and I have bought from them.
5. The SR20DET VRS gasket kit is effectively the same as the DE kit, it just has more gaskets. Pretty sure it comes with an o-ring suitable for the DE's distributer. Just make sure you get an S13 kit if your DE engine is from an S13, and an S14 kit if your DE engine is from an S14 or S15 Autech. Look at the rocker cover; flat is S13 and a bump at the front is S14/S15. They use different oil pumps, and that's where the bump comes from, so don't buy the wrong one.
Depending on the work you're doing, I might have most of the gaskets you need, which I can sell for a decent price (I don't envisage rebuilding another SR20 any time soon). I ended buying 2 OEM VRS S13/redtop gasket kits to rebuild a pair of engines, then plans changed due to one engine being farked, so I took some pieces (mostly valve stem seals iirc) from one of the kits and put the rest on a shelf. This would probably be your best bet at an economical solution.
Let me know what you're doing, and I'll try to remember to check what parts of the kit I have on the weekend.
Your content will need to be approved by a moderator
Guest
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoticons maximum are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
