Sivilaz
Need urgent help please! Timing chain issue
Hi everyone I am in a stressed spot now, I was in the process of replacing one rocker arm, and that's all fine and fixed, though i put the cam shaft back on and torqued everything to spec even sprocket, had to do this whole process twice because some marks I made didn't line up. But once I lined everything up I have these 2 major problems:
* The silver links aren't lining up on the 2 dots, instead was working with someone on car and they made these marks ( I believe when I opened valve cover it was like that.
* The even bigger issue I cannot insert the chain tensioner because it won't go in, the bracket that holds the timing chain is solid as a rock and won't move. I have run out of options and don't know what to do. I'd really appreciate any help I could get (I've read the manual multiple times)
