QRI05E
SR20DET Max Power Output (RW/KW)
Hey Guys,
Im contemplating on buying an S15 Jap Spec or an R34 GTT and just want to see what kind of power they are making.
Having owned an R33 GTST for 3 yrs, I know the RB engine back to front however im not too knowledgeable on the SR20DET so would like some feedback.
In tems of stage 2 mods:
- Turbo Upgrade
- Injectors
- aftermarket ECU
- Fuel Pump
- FMIC
- Tune
How much power has the SR20DET known to produce with the above mods?
Just for a comparison, an RB25DET with above mods can easily come close to 280 - 300rw/kw on standard internals
Regards,
Sarkis
There are people pushing 280rwkw, some over 300rwkw with those sort of mods.
Depends on the turbo you use and if you wou don't mind a bit of lag...
If i was aiming for figures like that i'd be upgrading from stock internals or at least budgeting for a rebuild
**Edit**
Don't R34s run a different engine to a R33 (neo or something)?
a 6 cylinder 2.5 litre will always have the advantage, with the stage 2 cams and assuming you have all the other equivalent supporting mods and the right ECU/tune you will be able to pull out 300kwatw weighting 3/4 of what a boat does.
it also depends on what you are gonna use the car for. If it is a show off at the red light kinda thing and at the drags the Rb25neo and upper castor arms will be better.
if its a true sports fun car and handling go for the s15.
If your chasing big HP then go the 6 cylinder it will always make more power, If you want a fast light fun car then go the S15 with mods.
If you want to scare your self get a S15 and drop in the RB25. its easy and you get the best of both worlds.
imo there is more potential in a s15 than a r34gtt
rb25's dont have all that great of aftermarket support especially not compared to a sr20 anyways.
jap specs = :wub:
^^^^im with that^^^^ putting the rb25 in the s15 that is!
but 2 give u some idea...
180sx -blacktop sr20.
HEAD.
stage 1 cams
1.2mm headgasket
rocker arm stoppers
ENGINE.
Stock Internals.
trust t518z turbo
trust exhaust manifold
full stainless blitz exhaust
apexi power intake kit
apexi power fc
nismo 740cc injectors
bosch 040 fuel pump
greddy intercooler (kit)
blitz id d2 electronic boost controller
tune and running 22psi
261.3 rwkw on sam cornell (dr drifts) dyno!!!
drive train and every thing else i wont even bother listing as they dont make extra power just more reliability.
add up the money just in performance parts............
for me the choice is easy rb all the way
Thanks Guys! Its a hard choice especially cause the S15 is a lot lighter than the R34 making it quicker on short sprints. I guess the choice will come down to finding the right car at the right price...
