180sxnit
Fuel Filler Neck
Hi Guys, Lately i have noticed a strong fuel smell in the cabin, I have tried replacing all lines, Fuel filter, The two lines that run out of the tank and still didnt fix the problem i then looked at the "fuel filler neck" the little restrictor that compliance places put in the tank...
threw searching on the forums i found posts on this but no one had any pics and in some of the threads people had asked for pics or a how to, so i did mine today and thort i would share some pics and let you know how i did it.
(very simple to do btw)
what i needed
x1 screw driver
x1 tube of sikaflex(purchased from bunnings for $26.50)
Some thinners or a cleaning agent
Step 1, Open fuel flap and remove petrol cap
Step 2, Get screw driver and there is a lip on the restrictor put it between the restrictor and the filler neck, Twist the screwdriver and work your way around till it pops out a bit,
Mine was dodgy and had old dryed up sealant so i could then pull it out with my fingers but you may need plyers and give it a gentle pull.
Step 3, Get your thinners or other cleaning agent and give the restrictor a good clean also clean around the filler neck
Step 4, Put sikaflex around the egde of the restrictor i found spreading it with your finger to be easyer
Step 5, Place the restrictor back in and gently tap it back in to place
Now all you have to do is wait for it to dry and your done
Hope this helps
Trent
Im not sure we have those over here in new zealand but when the nissans get a fuel smell in the car its usualy the large rubber O ring seal for the fuel tank is not working or fitted properly, easy as going to a wreaker and getting a new one, then the smell goes!
Edited by PRYMORTAL
yeah i have checked my o'ring in the tank as well but its fine its not stretched or perished just wanted to make up this how to :)
Thanks mate
I've always not bothered to go diggin for the fuel smell in the 180...I'll try this.
Glad u got pics too :thumbsup:
good stuff
Thanks mate
good stuff
haha yeah it was actually you that i noticed were asking for pics in a previous thread
Thanks mate
good stuff
:lol:
and since...I've never bothered to go back and try and fix it.
I just might now haha
+1 for doing this, I used expoxy resin on mine ages ago, I cannot recommend enough!! so easy to do and say goodbye fuel smell
where can i buy a new restictor? my flap has gone loose and it pretty much stays open
Any where that does ADR compliance will have them.
hi guys,
I have a related problem. My tank doesn't seem to seal properly, though I rarely get fuel smell in the cabin. The cap never has any pressure in it at all - you know how normally when you take off the cap it hisses a little? Nothing from mine. The other thing it does is under HARD cornering, fuel spills out of the fuel flap. Any ideas what's wrong?
try doing what i have done in this guide
also have a look at the filler neck itself it may be cracked/split some people in other posts have reported such problems
I followed all the guides on nissansilvia.com and took into account everyones thoughts.. but all were useless.
Turns out the large o-ring on top of the fuel tank, which houses the top part of the fuel pump has totally crumbled, the old owner replaced the fuel pump, but not the seal (moron).
Went to Nissan and ordered a new one, under $20.00. 10mins later, no more fuel smell and everytime I open the fuel cap its pressurised and goes pssh...
could a mod possibly move this to the "technical articles" section plssss :)
i replaced hoses all over the car trying to solve this problem and i had a new oring from when i fitted a walbro pump. couldnt fix it...till now.
im so glad i stumbled onto this article.
i was wondering how the sikaflex has held up against the fuel, i have this problem and a caulk of sikaflex 291 which says it's "fast curing marine adhesive /sealant and bedding compound" i cant find any info on whether it is resistant to fuel... i was also thinking of using 2 part epoxy glue. Thoughts?
Just did this the other day to my mrs r32. fuel smell GONE! thanks mate.
sorry to drag out an old thread but thanks for this write up :) ive just finished and i hope its my problem :)
Does anyone have an answer to this?
ive hadd silkaflex on for 2 years(i fixed the exact same issue except mine was actually spilling fuel) and no issues...
so ill say it will last you for at least 2 years? :P
we use a 2 part body sealer type glue at work for hilux bonnet recalls, squirted some on a razor blade last week and let it set, had it sitting submerged in fuel for the last 6 days and it hasn't gone soft or broken down so im going to give it a run tonight. there is also some kind of sealer on the market that actually says its fuel resistant if you are worried about other kinds of sealers, im not sure how much it costs but we use it for sealing long range fuel tanks that we fit to some 4x4's
Thanks for the help, soon sorted the fumes coming through the cabin in mine. Yaya
my flap has gone loose and it pretty much stays open. Lol
that's what she said.
Mine doesn't have that restrictor thing, just an open hole when you remove petrol cap. Have never notice fuel smell in the car :/.
