Phobos
Power figures for stockish setups
Unless you guys are comparing cars on the same dyno and at the same time of day, your comparison is useless. If you're that concerned, take it to a happy dyno and then go down the pub and brag your nuts off!!!
regardless of dyno, for what he has, its not right.
ive seen dyno differences as high as 20kw..... add another 20kw on to his original figure and people would say "yeah, that seems about right". The only thing that seems out of the ordinary is his boost level. For people to sit back and start bagging a tuner when they have no idea about the conditions the car was tested under is stupid.
Make and model:
1990 180sx
Size/Type of engine:
RB25DET
Transmission: Manual/Auto
Manual 5 Speed (RB20 Box)
Modifications to the car(detailed):
1) 3" turbo back exhaust and air filter
2) Walbro Fuel Pump
3) FMIC
4) Turbosmart Bleed Valve
Boost level:
10 PSI
Power Output (rwhp):
220rwhp
900 ft. lbs. (Torque) (that's at 3000rpm, LOL) holds pretty much all the way to redline.
Extra: Standard Computer. Just threw that Boost Tee in and 10psi later that's my figure...lol.
Cheers,
MaTT
That implies you were making ~500 hp at 3000 rpm.
Sure about that?
:blush:
you can't convert torque to hp ......
http://www.largiader.com/articles/torque.html
Torque and power are inescapably linked by the fact that horsepower equals torque (in ft-pounds) times RPM divided by 5250, so people who talk as if they are independent are full of it.
900x3,000 = 2,700,000
2,700,000/5,250 = ~514HP
Made a similar thread a while back but mods closed it coz it was apparently a repost of a pinned Turbo Reference Guide So attempt No.2
This thread is like "Turbo Reference Guide" but ONLY for cars with stock turbos, so people who have stockish setup can see how healthy their engine is and how effective some bolt on mods are in comparison with other similar setups.
NOTE TO MODS: Please don't close this as it's NOT the same as "Turbo Reference Guide" it's more like "Stock Turbo Reference Guide"!!! Thanks
Anyway the format is as follows:
Make and model: 180sx
Size/Type of engine: SR20DET REDTOP
1) Trust GTR Twin Inlet Cooler (Tube n Fin)
2) 3 Inch Dump/Front, 3 Inch Cat-out pipe, 3 inch cat-back apexi n1
3) K&N Pod
4) Walbro 500
Boost level:
12psi (13 on a cold night)
Power Output (rwkw):
RPM's Dyno: 173 (Previous owner, before fuel pump and with some cheap shitty pod)
Turbo Tune: 159 (current mods, but possible with leaking turbo & dump gasket, and a VERY blown manifold gasket)
Make and model: S13
Size/Type of engine: CA18DET 91' 1809cc (S14 BB)
Transmission: Stock CA w/ Cushioned Button
1) ARC FMIC
2) 3" Turbo back GKTech exhaust
3) Walbro pump
4) S14 BB w/ HKS actuator
5) Apexi Pod
Boost level: 10psi (0.6) bar
Power Output (rwkw): 155rwkw / 207.78hp
Make and model: Datsun 1600 71'
Size/Type of engine: SR20DET Black top VCT
Transmission: Manual/twin plate clutch
1) custom front mount
2) VL turbo pump with surge tank and primer, 850cc rx7 injectors
3) Rush Pod
4) Profecb 2
5) engine is japspec so what ever the jap s14 stock turbo is
Boost level:
12psi = 180rwkw (standard plugs)
19psi = 203rwkw (plugs need smaller gap (0.6mm))
full boost on 19psi at 3250 rpm
Make and model: 1995 180sx
1) 3inch catback exhaust
2) GFB boost controller
3) Walbro (copy)
Boost level: 12psi
130rwkw
Make and model: 1994 S14Zenki
1) 3inch exhaust, from front pipe back
2) Blitz DSBC-r boost controller
3) Unknown Pump, def aftermarket though.
4) Z32 AFM
5) 550cc injectors
6) Sard FPR
7) Blitz pod
8) Tomei poncams, 256x11.5
9) Power FC
10) 60mm DE throttle body
Boost level: 1.2bar
214rwkw
Mine is on the turbo reference thread, but I made 180.2rwk on a hot day, stock injectors and cams.
190.2kw
ADM S14 (150,000kms - standard engine)
Flywheel/clutch package
Trust M Spec FMIC
Trust AirNX pod
Trust Profec B Spec II @ 1bar
Trust PEII catback+catout pipe+dump/front pipe
next im getting Z32 AFM + remapping standard ecu and also hiflowing my injectors to 700cc - hoping for 210kw... then next stage in january next year is gonna be HKS step 2 264 11.5mm lift cams, HKS cam gears and springs/retainers/ras kit
oh and btw... my goal is to beat gee200 and break 230kw on bp98 and standard turbo... ive made a bet with a few other mates... so money is on the line!
Make and model: 1997 180sx Type X
Size/Type of engine: SR20DET Blacktop
1) Blitz FMIC
2) 3 Inch Nismo exhaust
3) K&N Air filter
4) HKS EVC
Boost level: 8psi / 11psi
Power Output (rwkw): 130rwkw @ 8psi and 149.7rwkw on 11psi with boost dropping back to 9psi at redline due the HKS EVC not holding boost.
Make and model:180sx 94
Size/Type of engine:sr20det black top.
1) ......Pod filter
2) ......ISC Fmic
3) ......blitz dual solinoid EBC
4) ......3 inch turbo back
Boost level:8psi low and 14psi high
Power Output (rwkw):??
never had it dynoed. what kinda power rwkw should i be expecting?
love these threads ;) working in these purist boundaries gets a chubby going...
s1 200 sx
040
remapped ecu
decat back 3"
air filter
fmic
bled to 15psi
184kw
blowed the oil seal in the stock t28, got a new t28bb +tomei dump and front pipe come monday!!
some s15 injectors and better afm may get some scope to the magik 190+with some good tinkering..heres hoping anyways!!!
Edited by dam-re1
Hi guys
Just made 163KW on 15 PSI on my s15 but was told that its really bout 185 duw to it being done in 4th and 5th its a closer 1:1 ratio for the s15 but yea
mods are
FMIC
PFC
Pump (unknown brand)
3in ex
z32
Plans T518z 8cm
Stage 2 cams
injectors
The car is nice to drive and im very happy with the new built motor (done by street force TOP WORK)
Hey mate any updates??
did ya get ya 210rwkw
made 194.8kw on 18psi with the cams
timing is retarded on the cams and need an adjustable gear... so my valves arent shutting correctly... so ive got the hks adjustable exhaust pulley now
will be going on this saturday and hopefully my car wont run like a laggy bucket of poo
Make and model: S13
1) GKTECH tube and fin FMIC
2) GKTECH 3 inch Turbo back exhaust With METALCAT high flow CAT
3) Greddy Profec B Spec II boost controller
4) Walbro Fuel pump
5) K'n'N Pod Filter
Boost level:
13psi
Power Output (rwkw): 154.6kw in the middle of the day up in North QLD
