silover
Latency Issue With S15 480cc And Nismo 740cc
had a bit of articles search and found that
Apexi PFC manual indicated 448cc for S15 but some says 480cc as standard
So if it is 480cc then latency is either 0.5ms or 0.78ms from what I found on the net.
As for the Nismo 740cc it is 0.66ms
So is the latency diff 0.16 or -0.12ms?
That is a real big difference and will affect how the car runs so please specify if you know this please.
Jap Spec S15 injectors are actually 448cc at standard fuel pressure, 480cc is some stupid number everyone has been posting up. (Waits for K/B warriors to spam saying their 480cc at standard pressure)
S15 Injectors
Latency 0. 77ms 2.55 450cc
Latency 0. 78ms 3.05 490cc
Latency 0. 79ms 3.55 525cc
Latency would be 0.77-0.66 = 0.11ms
Correction would be 450/740 = 60.82%
INJECTOR CORRECTION
- Formula = stock 448cc divided by nismo 740cc = 0.60cc x 100 = 60.54%.
So i would go into the ecu and change the INJ correction to 60.54%
"INJECTOR LATENCY CORRECTION"
From what i have found the latency for the nismo's is 0.66msec and stock is 0.77msec
- Formula = nismo 0.77msec minus stock 0.66msec = 0.11ms
So i would change the INJ Latency numbers for each injector to 0.11msec
hope this helps. btw im just going off the figues you have posted up
calculations listed there are back to front
latency formula is new minus old
nismo minus stock
.66 - .78
= -.12
480cc is at 4 bar fuel pressre not 3
Edited by woznoz
This is true, the 200SX is at 3 bar and the Silvia is at 4 bar due to the power difference.
