drifts13
S15 - Will JDM cluster fit straight into ADM model
hi guys
just a kwik question?/
my mates cluster in his s15 200sx needs to be replaced.,,,,,
weve found a jap spec cluster and was wondering if this was a straight swap??? just unplug the adm cluster and plug in the jap spec one?? or is modification necessary
Are you 100 % sure ?
Only reason i tried fitting an S14a CLuster in a Series 1 S14 and there is one less connection at the back of it...
I realise your asking about a S15 but cant confirm this one...
Perhaps the S15 ADM>JDM MAY be different as per the case in the S14's ?
Only reason i say that i tried fitting an S14a CLuster in a Series 1 S14 and there is one less connection at the back of it...
yes im talking about an
Jap Spec s15 cluster into a ADM S15 which has the stock ADM cluster
Has anyone swapped a JAP SPEC cluster into an AUS spec 200??? can someone confirm that the plugs fit 100%.?? no modding required
organised to pick up the cluster soon
from what i have read yes
inx75y that because you went for zenki to kouki
if you got a zenki JDM cluster it would be plug and play
ive got a JDM jouki cluster on the way for my s14a and it is going to be a plug and play affair ;)
Realise that just saying the S15 ADM to JDM may have a different number of connections on the back of it !
thanks for that,,
dont particularly want to be fiddling around with the wiring and harnesses on the back,,,,
might pass on this job....
YES IT WILL FIT!
I currently have a JDM Manual cluster in my ADM AUTO S15. So you can even use different transmission's clusters obviously loosing/gaining the indicator stating what gear you are in and over-drive.
But yes, no modifications needed. Unscrew, unplug the 3 plugs into you current cluster and the plug the new one in. Remembering km's are recoreded individually by each cluster so you will get a different reading!!
No mods required, I went from a ADM to NISMO to JDM back to ADM, they are all identical.
