ISC Performance
Polyurethane Engine and Gearbox mounts- S13/S14/S15
Our engine and gearbox mounts are made from polyurethane and aluminium to ensure the highest quality for your vehicle! These mounts are alot stronger then your worn out factory items and the material they are manufactured from will make them stiff/strong whilst absorbing alot of the vibration caused by your engine and gearbox. The bolts that are included in the kit are also a high tensile item.
Gearbox Mount = $125
Engine Mounts = $125
Gearbox/Engine Mounts together = $225
hey guys,
just wondering if you do the poly urethane engine mounts for a early r32 running with rb20 running gear??
if so how much??
thanx sly13
