s13 brap
external fuel system setups
just about to start on my fuel system and trying to get some ideas of the layout and how different systems look..
i have 2x 044 pumps
2.5l surge tank so far,still have to get speedflow fittings..
anyone have pictures of similar setups in silvia's??
im using a sard surge tank
the external pumps are housed inside the surge tank to limit space and noise
surge tank can hold 2 pumps
My setup will be similar to the following, Can have the rear section covered and if ever pulled over nobody would be the wiser if i had to open the boot.
So is it fine to relocate the fuel filter to in between the exit of the surge tank and the high pressure pump? Tidy up the engine bay a little.
you wouldnt need a surge tank for street use unless your a sick speed racer and redline it in first and second from every traffic light, or have an extreme forced induction and fuel system to require the external pump and surge setup
old setup..
will be changed before i get it running again..
Thanks heaps for the pics guys ,str8e18e that setup is awsome!! Great insparation.
another dumb question.
what consists of a surge tank setup?
like s1l80's old one
a lift pump( intake pump)pumping into the sure tank and an external pump sucking from surge tank feeding the engine
Those fittings would have cost a fair bit!!
Tough
lol it has no cover on it.
Sweet setup str8e, those hard lines must've taken ages to do. I like the way you've done the top tank fittings. Are they brazed on? What lift pump are you running?
u mean the fittings welded onto the lift pump bracket? its tig welded
lift pump is a standard fuel pump
can you have too big a pump as a lift pump? i am looking at fitting a surge tank, mainly because my car will be used on the track, and i have a 040 in tank. Is this too big? would be using a single 044 external
yes u can
u will just be filling up ur surge tank quicker and it will just over flow into the fuel tank via the return line to the fuel tank
How do you go about starting a fuel system with a surge tank for the first time? Seems like it would be pulling alot of air through for a while
keep cranking the engine over till it starts it will bleed itself
nothing special
What's the odds of standard pumps dying as lift pumps? I'm bout to purchase all my stuff but bit worried that having a good setup is ruined by the stock pump
I'm using my stock pump as a lift pump for years now it's never let me down
Comes down to the condition of your stock pump tho
I yeh I think I got a ca pump in there still might just go gtr n either run 044 or 070 what pumps better for 300~hp
my setup.. Does the job. Bosch 044 external and unknown sized surge tank..
Surge setup i made in my 180, you get no fuel smell with the solid lines either ;)
