TAARK
Genuine Nissan Parts! + NISMO Parts!
We now have a new supplier with lower prices! So the savings are past onto you!
If you can't find the part your looking for feel free to PM me and we can order it in!
All parts are in stock and ready to ship!
NISMO PARTS
Nismo Engine & Gearbox Mounts
Description:
Nismo mounts are 30-40% stiffer which makes motor shake less at idle and the Nismo transmission mount provides precise shifting at high rpm from reduced motor/transmission movement.
Application: S13/180sx, S14, S15
Price: $350 per set
Or buy separately
$130.00 LH Engine Mount
$130.00 RH Engine Mount
$120.00 Gearbox Mount
Nismo Black Aluminum Gear Knob
Description:
Genuine Nismo gear knob. CNC machined from solid aluminum and anodised black.
These will fit any nissan with a 10mm Thread. Most 5spd nissan (S13 S14 180sx etc)
Price: $100.00
Nismo Radiator Caps
Description:
Nismo radiator caps... Higher holding pressure for better cooling. 0.3Mpa (1.3kg/cm2)
Will suit all Nissans
Price: $65
Nismo Thermostats
Description:
Regular thermostat opens at 76 degree C, Nismo thermostat opens at 65 degree C for better cooling. Results in at least 5 degress C lower at Full throttle acceleration. A must for a modified engine.
Application: All SR20's $105.00
Application: All RB's $115.00
Nismo Big Clutch Slave Cylinder
Description:
These nismo clutch cylinders have a larger piston to create a softer pedal on those heavy and harsh clutches.
These are direct replacement for the standard ones.
Will suit S13/S14/S15 SR20 & CA18
Price: $200
Nismo Shift Stickers
Description:
Brand new genuine nismo shift stickers. A must have for those with aftermarket shift knobs without shift patterns on them. Keep the police happy!
Price: $5 each
5spd & 6spd versions available...
Engine Parts
CA18 Exhaust Gaskets
Description:
Ca18 exhaust gaskets. Genuine Nissan. 4 per engine needed.
Price: $12.00 each
CA18 Rocker Cover Gaskets
Description:
Ca18 rocker cover gaskets, if you have oil leaking from your rocker covers then you will need to replace these along with the half moon seals. 2 per engine.
Price: $30.00 each
CA18 Half Moon Rocker Seals
Description:
Ca18 rocker seals, if you have oil leaking from your rocker covers then you will need to replace these along with the main gaskets. 2 per engine.
Price: $9.00 each
CA18 Oil Pump
Description:
Always good to replace your flogged out oil pump when rebuilding your motor...
Price: $200.00
CA18 Oil Pump Gasket
Description:
If your rebuilding or replacing your CA18 oil pump then you will need a new gasket.
Price: $10.00
2 Bolt Exhaust Gasket
Description:
Replacement exhaust gasket 3"
Price: $12.00
3 Bolt Dump Pipe Gasket
Description:
Replacement exhaust gasket 2.75"
Price: $12.00
S13 Fuel Tank O-Ring
Description:
If your replacing your fuel pump then you will need one of these. The original ones stretch and never go back into place properly.
Price: $20.00
Z32 Fuel Filter
Description:
This a Z32 300zx twin turbo fuel filter, they flow more fuel with less restriction.
Use only the best genuine parts when servicing your pride and joy!
Price: $35.00
SR20 Injector Insulators
Description:
Replacing your injectors then it's best to replace those old and worn insulators.
Price: $30.00
SR20 Injector O-Rings
Description:
Upgrading you injectors? Then you will need new o-rings to install them!
Price: $21.00
S13 Intake Manifold Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan intake gasket.
Price: $17.00
S13 SR20 Collector Gasket
Description:
If your pulling your stock manifold off you will need one of these to put it back on again. These gaskets sit between the 2 halves of the intake manifold.
Price: $10.00
S14/S15 Intake Manifold Gasket
Description:
Price: $30.00
S14/S15 Collector Gasket
Description:
Price: $15.00
S13 IACV Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan idle air control valve gasket.
Price: $10.00
SR20 Throttle Body Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan throttle body gasket.
Price: $15.00
Genuine Nissan SR20 Coil Packs for S13/S14
Description:
Is your car miss firing or have you burnt a coil pack out? Then check out these brand new genuine nissan coil packs!
Price: $105.00ea
S13 SR20 Rocker Cover Gasket
Description:
If your rocker cover is leaking... Then replace that gasket! Comes with the spark plug well seals also!
Price: $45.00 (set)
S14/S15 SR20 Rocker Cover Gasket
Description:
Price: $40.00 (set)
SR20 Rocker Cover Studs
Description:
There are 2 sizes available. The outter ones and the center one.
Price:
Outter: $4.20
Inner: $3.00
SR20 Rocker Cover Washer
Description:
Ever lost one of these... Then look no further.
Price: $10.00 each
S15 7 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly and are re-usable. They come standard on the S15 SR20det and will work with any SR20det!
Price: $90.00
T25 & T28 Manifold -> Turbo Gasket
Description:
Blown your turbo gasket? Or just need a new one for when you pull it off?
Price: $30.00
T25 Turbo -> Dump Gasket
Description:
Price: $25.00
T28 Turbo -> Dump Pipe Gasket
Description:
Price: $20.00
T28 Oil Drain Gasket
Description:
Price: $5.00
T25 & T28 Turbo Compressor Inlet Gasket
Description:
Price: $10.00
T25 & T28 Turbo Compressor Outlet Gasket
Description:
Price: $10.00
T2 Turbo Locking Tabs
Description:
These bolt onto the turbo when fitting onto the manifold, once the nuts are done up the tabs are folded up to prevent the nuts from rattling loose.
Price: $9.00 each
S13 SR20 Water Pump
Description:
Always good to replace when rebuilding or if your having cooling problems.
Price: $95.00
S14/S15 Water Pump
Description:
Always good to replace when rebuilding or having cooling problems.
Price: $100.00
SR20 Power Steering, Air Conditioner & Alternator Belt
Description:
Genuine nissan fan belts.
Price: $35.00 each
SR20 Front Main Seal
Description:
Got oil dripping out from between your engine and harmonic balancer? Then theres a good chance it's this seal! So replace that old leaking front main seal today...
Price: $20.00
SR20 Rear Main Seal
Description:
Got oil dripping out from between your engine and gearbox? Then theres a good chance it's this seal! So replace that old leaking rear main seal today...
Price: $30.00
SR20DET Timing Chain Kits
Need to do your 100k service? Then you need to replace that worn out timing chain...
This kit includes:
Timing Chain
Fixed Chain Guide
Adjustable Chain Guide
S15 Timing Chain Tensioner
Tensioner Gasket
Pivot Bolt
2x Bolts
Price: $380
SR20 Timing Chain Tensioner
Description:
Got a noisy timing chain or rebuilding your motor, then replace your tensioner now... These are the updated S15 model with longer and finer adjustments!
Price: $100.00
SR20 Timing Chain Tensioner Gasket
Description:
Replacing your timing chain tensioner? Then you will need an new gasket.
Price: $10.00
SR20 Crank Timing Gear
Description:
These should be replaced when replacing your timing chain.
Price: $30.00
SR20 Oil Filter Block Seals
Description:
These seals are fitted between the oil filter block and engine block. Required for when fitting an aftermarket item or replacing an old one.
Price: $12.00 each
SR20 Oil Pickup/Strainer
Description:
This is the updated oil pickup the SR20. It has a slotted oil pick up so if the sump gets damaged your engine wont get starved of oil. Always a good idea to replace when rebuilding. It also has the support bracket moved back to prevent the strainer from snapping off.
Price: $40.00
SR20 Oil Pickup Gasket
Description:
If your replacing an oil pump or pickup you will need one of these.
Price: $10.00
SR20 Oil Pump Drive Collar
Description:
Always good to replace these when replacing an oil pump or rebuilding a motor. These tend to to wear out and destroy oil pumps.
Price: $18.00
SR20 Oil Pump o-ring
Description:
These o-rings are fitted between the oil pump and block on all sr20's. A must when replacing the oil pump or building a new motor.
Price: $10
SR20 Oil Pumps
Description:
S13 SR20 Price: $280 "1.5 week wait"
S14/S15 Price: $300
th_oilpump1Medium.jpg th_oil23Medium.jpg th_oil26Medium.jpg th_oilMedium.jpg
SR20 Oil Drain Plug Crush Washer
Description:
Always replace the drain plug crush washer everytime you remove your sump plug to prevent oil leaks.
Price: $3.00
S13 SR20 Oil Filter
Description:
Price: $15.00
SR20 Stock Thermostat
Description:
Genuine Nissan thermostats...
Price: $35
S13/S14/S15 PCV Valve
Description:
Known for causing problems in SR's... Replace that old valve today...
Price: $30.00
S13/S14/S15 SR20 Temperature Sensors
Description:
SR20's a known for sensor failures leading to all sorts of problems... So replace that old temp sensor now...
We have both S13 and S14/S15 sensors in stock...
S13 Price: $35.00
S14/S15 Price: $40.00
Genuine Nissan O2 Sensors for SR20's
Description:
Is your fuel economy bad? Then there is a fair chance that your O2 sensor has had it! Good to replace these on a yearly basis.
Price: $115.00
Skinny and Fat types available
SR20 Oil Pressure Sensor
Description:
Replacemtent oil pressure sensor for all SR20's. Genuine Nissan.
Price: $35.00
SR20 N/A Distributor Rotor Button
Description:
Replacement rotor button for SR20 N/A distributor.
Price: $30
SR20ve/SR16ve Parts
SR20ve P11 Intake Gasket
Description:
Pulling your intake manifold off or doing a VE conversion? Then you will need one of these.
Price: $30.00
SR20ve P12 Intake Gasket
Description:
Price: $30.00
SR20ve/SR16ve Rocker Cover Gasket
Description:
Price: $45.00 (set)
SR20ve/SR16ve Oil Pickup Gasket
Description:
If your replacing an oil pump or doing a VE conversion you will need one of these.
Price: $15.00
SR20ve/SR16ve Oil Pump and Front Cover
Description:
Always good to replace your flogged out oil pump when rebuilding your motor... Or if you are doing a VE conversion you will need one of these.
Price: $370.00
Drivetrain Parts
SR20 Flywheel Bolts
Description:
Genuine Nissan SR20 Flywheel Bolts. Always good practice to replace these whenever removing the flywheel as the bolts stretch.
Price: $8.00 each
SR20 Needle Bearing to Replace the Spigot Bush
Description:
These needle bearings replace the stock brass spigot bush in the end of the crank that the gearbox input shaft goes into. The needle bearings last longer and put less stress on the gearbox and are also quieter.
Price: $35.00
S13/S14 5spd Manual Front Gearbox Seal
Description:
Got oil leaking in your belhousing and dripping on the ground. Then this could be the seal thats leaking.
Price: $12.00
S13/S14 5spd Manual Rear Gearbox Seal
Description:
Got oil leaking around your tailshaft dripping on the ground. Then this could be the seal thats leaking.
Price: $20.00
SR20 5spd Shifter Plate Gasket
Description:
If you replacing your shifter or your standard one is leaking then you will need this gasket.
Price: $15.00
S13/180sx Gear Stick Dust Boot
Description:
Doing a manual conversion? Lost yours or have a broken one?
These bolt to the floor pan and seal around the gear stick to prevent oil and dirt out of the cabin...
Price: $75.00
S13-180sx Gear Stick Insulator
Description:
These bolt to the floor pan and seal around the gear stick to block out road and engine noise...
Price: $46.00
S13-180sx Gear Stick Retainer
Description:
These bolt to the floor pan and hold the 2 previous parts in place.
Price: $80.00
S13/S14 Gearbox Shifter Boot
Description:
Does you car smell like gearbox oil? Do you have oil around your shifter? If you do then this is most likely the cause!
Price: $15.00
SR20 Gear Stick Bush
Description:
Brand new and genuine nissan. Commonly worn part on S13/S14 shifters. Takes some of the sloppiness out of the shifter. Fairly simple to replace.
Price: $7.00
SR20 5spd Clutch Fork Dust Cover
Description:
Replacement clutch fork dust cover.
Price: $20.00
R200 Diff Main Pinion Seal
Description:
Putting a new diff center in or have a leaking diff? This seal is what you need!
Price: $40.00
R200 Diff Carrier Gasket
Description:
Putting a new diff center in? Then you will need a new gasket for re-assembly.
Price: $45.00
S13 Steering Rack Boots
Description:
Replace those old and cracked steering boots now. These come with fixing wire and o-ring.
Price: $35.00 each
Z32 Caliper Rebuild Kit
Description:
Includes everything to do a full caliper rebuild...
Comes with:
Seals
Boots
Clips
Lube
All genuine parts!
Price: $100.00
Z32 Reverse Switch
Description:
Brand new genuine nissan Z32 reverse switch.
Price: $50.00
Body Parts
S15 Bonnet Hinges
Description:
Brand new S15 bonnet hinges. Needed for S15 front conversions.
Price: $80.00 (pair)
S15 Headlight Brackets
Description:
Genuine Nissan S15 headlight brackets. Replace your damaged one or use in a conversion.
Price: $90.00 (pair)
S13/180sx Bonnet Rubber Stoppers
Description:
Missing some rubbers, or removing them for paint and want to replace them with new ones? Then look no futher!
Starting from the front:
Center Bonnet Rubber $9.00 each (2 required)
Main Bonnet Rubber $10.00 each (2 required)
Side Bonnet Rubber $7.50 each (2 required)
180sx Boot Rubber Stoppers
Description:
Price: $6.00 each (2 per required)
Silvia Lightening Badge
Description:
Replace that old badge today...
Price: $45.00
Silvia K's Badge
Description:
Price: $35.00 each
Interior Parts
S13 Gear Boot
Description:
These are BRAND NEW and GENUINE Nissan gear boots for 180sx and S13 models...
Price: $80.00
Genuine Nissan S14 Stereo Bezels
Description:
These are BRAND NEW and GENUINE Nissan plastic stereo bezels for S14 models...
Price: $110.00
can you get sr20 engine gasket kits ? how much ?
thanks
hi taark :) i txt you this morning, but no reply. u probly have a new mobile number now. anyway, i'm after for a nissan oem gasket kit or i think it's also called genuine vrs kit or any other brand coz my sr20det (s14a) needs a rebuild and a set of piston rings (4x) 86.5mm or 87mm im located in Brissy. can you give me a price for this items pls. thanks Glen 0402422506
S13 Gear Boot
Description:
Price: $80.00
Description:
Price: $110.00
Have these to suit S15s?
And can you also get a VTC unit + S14 S1 solenoid?
also rb25 gear box seals. the rear one and the shifter one
can you get sr20 engine gasket kits ? how much ?thanks
PM Sent
PM sent
S13 Gear BootDescription:These are BRAND NEW and GENUINE Nissan gear boots for 180sx and S13 models...Price: $80.00th_P1010065Small.jpg th_P1010066Small.jpgGenuine Nissan S14 Stereo BezelsDescription:These are BRAND NEW and GENUINE Nissan plastic stereo bezels for S14 models...Price: $110.00th_P1010008-1.jpg th_P1010009-1.jpg
Have these to suit S15s?And can you also get a VTC unit + S14 S1 solenoid?Cheers
Sorry, only S14. And the VCT units are still 4 weeks away.
Sorry, no RB parts just yet.
got a sr20 vct gearcheers
VCT units are still about 4 weeks away.
SR20 Rocker Cover Studs:
Do you have nuts to go with them?
Edited by mushroom
Do you have s14a gear boot ?? If so, how much posted ??
N also wit d nismo mounts, do they come with warranty ?? Coz my mechanic can get them for a lil more expensive but they come with supplier warranty so if it f**ks out they replace it for free..
SR20 Rocker Cover Studs:Do you have nuts to go with them?
We have them in stock they are stainless steel dome nuts. They are $1.50ea
Same for me mate.
Do you have s14a gear boot ?? If so, how much posted ??N also wit d nismo mounts, do they come with warranty ?? Coz my mechanic can get them for a lil more expensive but they come with supplier warranty so if it f**ks out they replace it for free..
No warranty, sorry. I am surprised that someone will offer a warranty just for the simple fact that you could break them if you try hard enough... We can't control what people do with their cars. ie. high HP cars break mounts quite easily and so do drifters.
Same for me mate.
cool, yehh i thought it was odd too.. ill find out more on that..
so do u have or can u get s14 series 2 shift boot console??
They are $380.00 + post.
More stock is arriving in around 4 weeks.
Taark
Same for me mate.
Sorry, we can't get these...
Taark
just brought a oil pump off taark, half the price compare to nissan dealers, paid and got the goods delivered to me the next day.
highly recommended sponsor, thanks heaps mate.
hi there, im after a standard rb20 headgasket, are you able to help me out or point me in the right direction of someone who can.
nissan needs to get them from japan and aftermarket ones are dearer then metal ones!
thanks in advance
I'm after one of the t28 dump pipe gaskets and a 3" 3 bolt dump/front pipe gasket if you can get one?
hi there, im after a standard rb20 headgasket, are you able to help me out or point me in the right direction of someone who can.nissan needs to get them from japan and aftermarket ones are dearer then metal ones!thanks in advance
PM Sent
PM Sent
Hi Taark,
can I please get a price and availability on:
1 x S15 collector gasket
1 x s15 spark plug well seal kit
1 x Rocket cover washer set
1 x T28 dump pipe gasket
1 x o2 sensor to suit s15
Delivered to 2750.
Thank, Dave.
P.s Need these parts by the weekend if possible
Hi Taark,
Delivered to 2750.
Thank, Dave.
PM Sent
S15 sr20det vct gear + postage to adelaide 5084
cheers
also can u get nismo oil caps?? :thumbsup:
Edited by NIS.S15
Quote for exhaust gaskets from the cat back pls. Nsw
edit: for s15 to suit blitz nur spec cat back exhaust (i think I need 2x 2 bolt exhaust gasket)
