cjmotor
Forced Perforamnce turbo Charger evo 4-9 (green-red- black )anti surge 84mm
Forced Performance Turbochargers have taken the EVO community by storm, often providing little if any trade off of response for power, lots of it
Forced Performance turbos are made in the USA and come with 12 months warranty
all instock in australia no more waiting
we match all price
please pm us
FP green turbo evo 4-9 selling $2550+35 shipped
The FP GREEN is the most responsive* bolt on turbocharger in the FP range available for the EVO 4-9. It features a 54lb/min 73mm HTA compressor wheel and a new 65mm revision of the high efficiency turbine wheel used in the FP RED for the perfect combination of power and rapid spool.
Compressor Inducer diameter: 52.6mm
Capable of up to 280kW at the wheels with supporting modifications
*As responsive as a standard turbo
FP RED Turbo: EVO 4-9 selling $2700+40 shipped
The FP RED offers serious power whilst keeping response down low for those past the entry level modifications stage. The larger inlet configuration helps reduce huffing and surging sounds that are often reported with larger stock format hybrids when lugging the engine at low RPM and high boost pressure, but perhaps even more useful is the way it helps feed the splitter blades of the compressor wheel resulting in increased flow. This larger inlet also increases the volume of the intake air pipe and reduces vacuum at the inlet of the turbo.
Note * 3” intake pipe recommended
Typical boost threshold about 3700rpm depending on camshaft selection and other variables.
Compressor Inducer Diameter 54.8mm
Full boost expected at around 3700rpm depending on supporting modifications and cam combination
Capable of over 320kW / 440hp at the wheels on a built engine
FP black evo 4-9 $2950+40 shipped
The FP BLACK is the most fully evolved stock appearing variant we offer. It features an 82mm HTA compressor wheel with a flow rate of 68lb/min with our 84mm Flow Advancement compressor cover. The turbine side features a large 67mm turbine wheel.
All FP Black’s come standard with a 25psi wastegate actuator and FP’s Evo Oil Filter Housing Line Kit.
Compressor Inducer Diameter 59.1mm
Capable of over 400kW / 500hp at the wheels on a built engine
:stretcher:
all instock
we match all price
please pm us
