TAARK
SR Parts!
SR20 ENGINE PARTS
Return to Menu
S13/180sx Power Steering Feed Hose
Description:
Sick of leaking power steering fluid? Then this might be the line that needs replacing... Also used when doing a SR - CA conversion.
Price: $50.00
S13/180sx Power Steering Return Hose
Description:
Price: $50.00
2 Bolt Exhaust Gasket
Description:
Replacement exhaust gasket 3"
Price: $12.00 (OUT OF STOCK)
3 Bolt Dump Pipe Gasket
Description:
Replacement exhaust gasket 2.75"
S13/S14/S15 SR20 Gasket Kits
Specify when ordering.
Description:
Rebuilding your motor? This is a full genuine nissan gasket kit
Comes with:
Nissan silicone gasket (orange)
copper oil drain crush washer
stock size headgasket
rear main crankshaft seal
timing chain tensioner gasket
valve stem seals (16)
valve cover gaskets (main and spark plug well gaskets)
front main crankshaft seal
intake manifold collector gasket
intake manifold gasket
exhaust manifold gasket
turbo inlet gasket
turbo outlet gasket
intake inlet tube gasket
oil strainer/pickup o-ring gasket
fuel injector o-rings (4 upper, 4 lower)
cam angle sensor gasket
throttle body gasket
water temp sensor gasket
AAC valve gasket
Oil Line Copper Washers (2)
Water Line Copper Washers (6)
Oil Filler Cap Seal
Turbo Oil Drain Gasket
Prices:
S13 SR20det “redtop” $230.00
S13 SR20det “blacktop” $230.00
S14 SR20det $250.00
S15 SR20det $230.00
S13 Fuel Tank O-Ring
Description:
If your replacing your fuel pump then you will need one of these. The original ones stretch and never go back into place properly.
Price: $20.00
S14/S15 Fuel Tank O-Ring/Seal
Description:
Price: $20.00
S14/S15 Fuel Tank Lock Ring
Description:
Swapping your fuel pump? These tend to strip and get damaged when removed. Best to have a spare just in case.
Price: $10.00
SR20 Fuel Filter
Description:
Use only the best genuine parts when servicing your pride and joy!
Price: $30.00
Z32 Fuel Filter
Description:
This a Z32 300zx twin turbo fuel filter, they flow more fuel with less restriction.
Price: $35.00
S13 SR20 Injector Insulators
Description:
Replacing your injectors then it's best to replace those old and worn insulators.
Price: $30.00
S14/S15/P11 SR20 Injector Insulators
Description:
Price: $25.00
SR20 Injector O-Rings
Description:
Upgrading you injectors? Then you will need new o-rings to install them!
Price: $21.00
S13 SR20 Fuel Rail
Description:
Need a new fuel rail to make your engine bay look brand new?
Price: $70.00
S13 Intake Manifold Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan intake gasket.
Price: $12.00
S13 SR20 Collector Gasket
Description:
If your pulling your stock manifold off you will need one of these to put it back on again. These gaskets sit between the 2 halves of the intake manifold.
Price: $10.00
S13 SR20 Manual Throttle Position Sensor (TPS)
Description:
Got a broken TPS, not reading correct voltages then replace it today. This is a common problem on the SR motors.
This sensor is for Manual cars only.
Price: $180.00
S14/S15 SR20 Manual Throttle Position Sensor (TPS)
Description:
Price: $90.00
S14/S15 Intake Manifold Gasket
Description:
Price: $30.00
S14/S15 Collector Gasket
Description:
Price: $15.00
SR20 Intake Bolt
Description:
Pulled your intake manifold off and lost or broken a bolt or just want to replace them? Look no further! Genuine Nissan.
Price: $2.00ea
SR20 Intake Stud
Description:
Pulled your intake manifold off and lost or broken a stud or just want to replace them? Look no further! Genuine Nissan.
Price: $1.60ea
SR20 Intake Nut
Description:
Pulled your intake manifold off and lost or broken a Nut or just want to replace them? Look no further! Genuine Nissan.
Price: $1.50ea
S13 SR20 IACV Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan idle air control valve gasket.
S13 = Price: $8.00
S14/S15 IACV Gasket
Description:
Price: $5.00
S13 SR20 Throttle Body Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan throttle body gasket.
Price: $10.00
S14/S15 Throttle Body Gasket
Description:
Price: $5.00
SR20 CAS
Description:
Brand new and genuine nissan CAS for the SR20 RWD motors.
Fix that ignition problem...
Application: S13/180sx, S14, S15 SR20's
Price: $360.00
SR20 CAS O-ring
Description:
Got oil leaking around your CAS? THen replace the o-ring and fix the leak today!
Price: $10.00
S13/S14 SR20 Igniter
Description:
Replacement igniter for SR20's in S13/S14 cars.
Price: $300.00
Genuine Nissan SR20 Coil Packs for S15
Description:
Is your car miss firing or have you burnt a coil pack out? Then check out these brand new genuine nissan coil packs!
Price: $100.00ea
SR20 Coil Packs for S13/S14
Description:
Price: $100.00ea
S13/180sx SR20 Coil Pack Cover
Description:
Replace that lost, broken or dirty coil pack cover today and make your engine bay look great!
Price: $60.00
SR20 Hydraulic Lifter
Description:
Building a new motor or have a collapsed lifter, then get genuine nissan lifters here!
8 Required
Price: $56.25ea
SR20 Rocker Arm
Description:
Building a new motor or snapped a rocker arm? Then get genuine nissan rocker arms here!
8 Required
Price: $37.00ea
SR20 Intake & Exhaust Valve Stem Seals
Description:
Building a new motor or just need to refresh a head. Get your genuine valve stem seals here!
8 Required of each required
Prices:
Intake: $6.00 each
Exhaust: $6.00 each
Genuine Nissan S15 VCT Unit
Description:
Got a rattle on your VCT SR20 motor that just wont go away? There is a very good chance this part has worn out. Replace it now!
Price: $400.00
Genuine Nissan S15 VCT Solenoid
Description:
Price: $120.00
SR20 Cam Squirters
Description:
Are your oil squirters clogged and not oiling your expensive cam properly? Replace them before you do permanent damage.
Intake Price: $42.50
Exhaust Price: $42.50
SR20 Head Bolts
Description:
These should be replaced every time the head is removed as they stretch. These are genuine Nissan.
10 required
$7.00 each
S13 SR20 Rocker Cover Gasket
Description:
If your rocker cover is leaking... Then replace that gasket! Comes with the spark plug well seals also!
Price: $30.00 (set)
S14/S15 SR20 Rocker Cover Gasket
Description:
Price: $30.00 (set)
S13/S14 SR20 Rocker Cover Studs
Description:
There are 2 sizes available. The outer ones and the center one.
Price:
Outer: $4.00
Inner: $5.00
S13/S14 SR20 Rocker Cover Washer
Description:
Ever lost one of these... Then look no further.
Price: $6.60 each
S15/P11/P12 SR20 Rocker Cover Washer
Description:
Price: $7.00 each
S15 Outer Rocker Cover Bolt
Description:
Missing or snapped a rocker cover bolt? Then look no further!
14 required
Price: $5.00ea
S15 Center Rocker Cover Bolt
Description:
1 required
Price: $6.00ea
S13/S14 SR20 Exhaust Stud
Description:
Pulled your manifold off and lost or broken a stud or just want to replace them? Look no further! Genuine Nissan.
8 Required
Price: $8.00ea
S13/S14 SR20 Exhaust Washer
Description:
Pulled your manifold off and lost a washer or just want to replace them? Look no further!
8 Required
Price: $3.40ea
S13/S14 SR20 Exhaust Nut
Description:
Pulled your manifold off and lost or broken a Nut or just want to replace them? Look no further! Genuine Nissan.
8 Required
Price: $2.00ea
S15 SR20 Exhaust Nut
Description:
8 Required
Price: $2.00ea
S15 7 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly and are re-usable. They come standard on the S15 SR20det and will work with any SR20det!
Price: $55.00
S15 3 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly. They will work with any SR20det!
Price: $40.00
SR20 parts continued in the next post…
T28 Turbo Gasket Kit
Description:
All those handy gaskets in one neat little kit!
Comes with:
1x T2 Turbo Gasket
1x T28 Dump Gasket
4x Water Feed Washers
2x Oil Feed Washers
1x Oil Drain Gasket
1x Compressor Inlet Gasket
1x Compressor Outlet Gasket
Price: $60.00
T2 Manifold -> Turbo Gasket
Description:
Blown your turbo gasket? Or just need a new one for when you pull it off?
Price: $30.00
S15 T2 Manifold -> Turbo Gasket
Description:
This is the S15 multi layer metal turbo gasket. A better option than the standard type.
Application: S13/180sx, S14, S15 SR20det's
Price: $35.00
T25 Turbo -> Dump Gasket
Description:
Price: $25.00
T28 Turbo -> Dump Pipe Gasket
Description:
Price: $20.00
T25 Oil Drain Gasket
Description:
Price: $5.00
T28 Oil Drain Gasket
Description:
Price: $3.00
T25 Metal Oil Drain
Description:
Swapping turbos or got an oil leak? You will need this drain tube.
Price: $20.00
T28 Metal Oil Drain
Description:
Price: $40.00
T28 Rubber Oil Drain
Description:
Swapping turbos or got an oil leak? This rubber hose can perish over time and should be replaced.
Price: $20.00
T25 & T28 Turbo Compressor Inlet Gasket
Description:
Price: $10.00
T25 & T28 Turbo Compressor Outlet Gasket
Description:
Price: $10.00
SR20 Oil Feed Copper Washers
Description:
These should be replaced every time you remove the banjo bolt to ensure you get a good seal. These are the updated version that are joined together so no more dropping and losing them!
Price: $4.00ea
SR20 Water Feed Copper Washers
Description:
Price: $4.00ea
T2 Turbo Locking Tabs
Description:
These bolt onto the turbo when fitting onto the manifold, once the nuts are done up the tabs are folded up to prevent the nuts from rattling loose.
Price: $7.50 each
T2 Manifold Nut
Description:
Lost or Damaged a nut when removing your turbo? New ones are right here. These bolt the turbo to the manifold. Genuine Nissan.
4 Required
Price: $4.50ea
T25 & T28 Manifold Stud
Description:
Lost or Damaged a stud when removing your turbo? New ones are right here. These hold the turbo to the manifold. Genuine Nissan.
4 Required
Prices:
T25 $4.50ea
T28 $10.00ea
T25 Turbo Dump Bolt
Description:
Lost or broken a bolt when pulling your turbo off? You'll need new ones! Genuine Nissan.
3 Required
Price: $4.00ea
T25 Turbo Dump Stud
Description:
Lost or broken a stud when pulling your turbo off? You'll need new ones! Genuine Nissan.
2 Required
Price: $10.00ea
T28 Turbo Dump Bolt
Description:
3 Required
Price: $4.50ea
T28 Turbo Dump Stud
Description:
2 Required
Price: $10.00ea
S13 SR20 Water Pump
Description:
Always good to replace when rebuilding or if your having cooling problems.
Price: $80.00
S14/S15 Water Pump
Description:
Always good to replace when rebuilding or having cooling problems.
Price: $90.00
SR20 Power Steering, Air Conditioner & Alternator Belt
Description:
Genuine nissan fan belts.
Prices:
SR20 Alternator Belt $35.00
SR20 A/C Belt $30.00
S13 SR20 Power Steer Belt $30.00
S14/S5 SR20 Power Steer Belt $30.00
SR20 Front Main Seal
Description:
Got oil dripping out from between your engine and harmonic balancer? Then theres a good chance it's this seal! So replace that old leaking front main seal today...
Price: $15.00
SR20 Rear Main Seal
Description:
Got oil dripping out from between your engine and gearbox? Then theres a good chance it's this seal! So replace that old leaking rear main seal today...
Price: $35.00
SR20DET Timing Chain Kits
Need to do your 100k service? Then you need to replace that worn out timing chain...
This kit includes:
Timing Chain
Fixed Chain Guide
Adjustable Chain Guide
S15 Timing Chain Tensioner
Tensioner Gasket
Pivot Bolt
2x Bolts
Price: $310.00
SR20 Timing Chain
Description:
SR20 Timing chain on it's own. This will fit all SR20de and det motors.
Price: $100.00
SR20 Timing Chain Tensioner
Description:
Got a noisy timing chain or rebuilding your motor, then replace your tensioner now... These are the updated S15 model with longer and finer adjustments!
Price: $90.00
SR20 Timing Chain Tensioner Gasket
Description:
Replacing your timing chain tensioner? Then you will need an new gasket.
Price: $10.00
SR20 Crank Timing Gear
Description:
These should be replaced when replacing your timing chain.
Price: $22.00
SR20 Woodruff Key
Description:
These woodruff keys are what locate the oil drive collar and harmonic balancer onto the crankshaft.
Price: $2.00 each
SR20 Oil Squirter
Description:
Broken an oi squirter? Or just want to replace them in your rebuild?
Includes squirter and the special bolt.
Price: $35.00 ea
SR20 Oil Dip Stick
Description:
Is your dip stick bent, or not sealing properly? Then replace it now!
Price: $25.00
SR20 Dip Stick Tube
Description:
Got a bent or broken dip stick tube? Or just want to put a new one on your new motor? Then grab one now.
Price: $20.00
SR20 Oil Filter Block Seals
Description:
These seals are fitted between the oil filter block and engine block. Required for when fitting an aftermarket item or replacing an old one.
Price: $8.00 each
SR20 Oil Pickup/Strainer
Description:
This is the updated oil pickup the SR20. It has a slotted oil pick up so if the sump gets damaged your engine wont get starved of oil. Always a good idea to replace when rebuilding. It also has the support bracket moved back to prevent the strainer from snapping off.
Price: $40.00
SR20 Oil Pickup Gasket
Description:
If your replacing an oil pump or pickup you will need one of these.
Price: $3.00
SR20 Oil Pump Drive Collar
Description:
Always good to replace these when replacing an oil pump or rebuilding a motor. These tend to to wear out and destroy oil pumps.
Price: $18.00
SR20 Oil Pump o-ring
Description:
These o-rings are fitted between the oil pump and block on all sr20's. A must when replacing the oil pump or building a new motor.
Price: $8.00
SR20 Oil Pumps
Description:
Always good to replace your flogged out oil pump when rebuilding your motor...
Will suit all Nissans
S13 SR20 Price: $280.00
S14/S15 Price: $250.00
th_oilpump1Medium.jpg th_oil23Medium.jpg th_oil26Medium.jpg th_oilMedium.jpg
SR20 Oil Drain Plug Crush Washer
Description:
Always replace the drain plug crush washer every time you remove your sump plug to prevent oil leaks.
Price: $2.00
S13 SR20 Oil Filter
Description:
Price: $12.00
S14/S15 SR20 Oil Filter
Description:
Price: $12.00
SR20 Stock Thermostat
Description:
Genuine Nissan thermostats...
Price: $30.00
SR20 Thermostat Housing
Description:
Genuine Nissan thermostat housing...
Price: $45.00
SR20 Bottom Radiator Hose
Description:
Brand new genuine nissan Bottom Radiator Hose for the S13/S14/S15 SR20 motors.
Price:
S13/180sx $40.00
S14/S15 $40.00
SR20 Top Radiator Hose
Description:
Brand new genuine nissan Top Radiator Hose for the S13/S14/S15 SR20 motors.
Price: $22.00
SR20 Upper Radiator Mount
Description:
Is your radiator loose, sitting low or have you just lost the rubber mounts?
Grab your new mounts here.
Price: $6.00
SR20 Lower Radiator Mount
Description:
Price: $8.00
S13/S14/S15 PCV Valve
Description:
Known for causing problems in SR's... Replace that old valve today...
Prices:
S13 SR20 $20.00
S14/S15 SR20 $22.00
S14/S15 PCV Valve Grommet
Description:
When replacing your PCV valve this should get replaced too as the rubber gets hard and doesn’t seal properly over time.
Price: $12.00
S13/S14/S15 SR20 Temperature Sensors
Description:
SR20's a known for sensor failures leading to all sorts of problems... So replace that old temp sensor now...
We have both S13 and S14/S15 sensors in stock...
S13 Price: $40.00
S14/S15 Price: $40.00
S13/S14/S15 SR20 Gauge Temp Sensor
Description:
If your temperature gauge in your dash has stopped working then this sensor will most likely be your problem.
Price: $25.00
th_S13TempSensor.jpg[/url
Genuine Nissan O2 Sensors
Description:
Is your fuel economy bad? Then there is a fair chance that your O2 sensor has had it! Good to replace these on a yearly basis.
SR20det "fat" Version $110.00
SR20det "skinny" Version $115.00
CA18det $120.00
S13 SR20de Silver top = "skinny"
S13 SR20det Red top = "skinny"
S13 SR20det Black top = "fat"
S14 SR20det Black top = "fat"
S15 SR20det Black top = "fat"
SR20 Oil Pressure Sensor
Description:
Replacement oil pressure sensor for all SR20's. Genuine Nissan.
Price: $30.00
SR20 N/A Distributor Rotor Button
Description:
Replacement rotor button for SR20 N/A distributor.
Price: $30.00
SR20 Knock Sensor
Description:
This knock sensor will fit all SR20's. Faulty units are a common issue with the SR20 family.
Price: $150.00
Do you stock any other interior parts for a s13.
Im looking for
Interior Door handle surrounds LHS/RHS and
Interior power window switch Surround LHS/RHS
The black plastic that sits in the doors.
Nismo Big Clutch Slave Cylinder
Description:
These nismo clutch cylinders have a larger piston to create a softer pedal on those heavy and harsh clutches.
These are direct replacement for the standard ones.
Will suit S13/S14/S15 SR20 & CA18
Price: $200
I have a 5 speed in my S15 the pedal is as stiff as hell. do I need to upgrade the clutch master as well or just the slave.
hey taark im chasing a brake master cylinder for a 93 180sx sr20det.. are you able to get one of those?? if so send me a pm with a price as i'll probs jump on it straight away..
thanks in advance brother..
Hey Taark, are you able to get hold of R33 h/brake cables? and if you can get hold of them, please PM me a price
Edited by benny200
Hey mate, I have a 95 180 black top. I'm after 4 outer cam cover studs, and 3 washers to go with. An 02 sensor, I think my model is the fat one??. And also can you recomend all the gaskets required to fit a new 2871r turbo, replacing a stock t25g and keeping the stock manifold.
Cheers.
also looking for fan / whatever else it runs around belt.
Thanks for the reply TAARK, yeah 1-2months is a little long to wait but if i can't get hold of any i'll PM ya
Can you get a hold of a new console and that bit of plastic that's goes around the gear boot and head unit. For s13
Could you PM me your projected price (I won't hold you to it if it turns out to be off the mark by a few dollars) for the R33 handbrake cables?
Contemplating my options atm.
interested in the Genuine Nissan S14 Stereo Bezels.. posted to Vic
Edited by fooyoh
can you get the door hinge brackets, pins and bushes for an r32 gtst???
TAARK do you still do the 6.5" speaker mounts for the front doors?
Able to get a clutch master cylinder suit s15.?? Will also need all your other nismo clutch related parts too but at the moment I can only find clutch pedals without a master.!!
Hi Taark was just wondering mate if you happen to have other CA18 engine mounts besides the NISMO ones
PM me Please
Scott
PM Sent
Hey Taark
How did you go with the original CA mounts?
Scott
Hey Taark
Price for S14 (s1) power window amp in drivers side door, and a price for the main switch assembly on the drivers side door mailed to 2228 Sydney.
Ash
After nismo clutch slave cylinder..got any left
S14 NISMO slave for clutch and the NISMO pivot ball , s14 water pump, front timing cover with oil pump and a full engine gasket rebuild kit
Prices for all and do you use a Aus or American supplier?
Dan
Guest
