cjmotor
Defi Link meter Advance Bf 60mm - White Red And blue -LED
Defi-Link Meter ADVANCE BF is gauge series which need to be connected to Defi-Link ADVANCE Control Unit.
ADVANCE BFs are electronic blacked out gauges which are high response and refined design. When the car is off they have a black face with no numbers on them. As soon as the car is turned on, the gauges light up and are in full affect.
  • *Defi-Link ADVANCE Control Unit (sold separately) is necessary to operate BF gauges.
  • *Defi-Link Meter ADVANCE BF is expressed as ADVANCE BF or BF gauges.
  • Turbo/boost/in-mani, oil press, fuel press, oil temp, water temp, exhaust temp, and tachometer are available.
  • Illumination color: White, amber red, and blue (The illumination color cannot be changed.)
  • Size: all kinds of 60mm gauges and 80mm tachometer
  • One ADVANCE Control Unit operates up to 7 gauges or displays
Movie
2 types of opening and ending modes between simple and HANABI version.
DAY
NIGHT
Warning
  • The product of Defi-Link ADVANCE SYSTEM cannot be connected with the product of Defi-Link SYSTEM. It is not compatible with the product of Defi-Link SYSTEM. Sensors are common in ADVANCE system and Defi-Link System except turbo sensor, but sensor wires are not common.
  • Defi-Link ADVANCE Control Unit is necessary to operate ADVANCE BF gauges
ADVANCE BF Tachometer 80mm series were released on February, 2011. The scales are 9000RPM and 11000RPM. The illumination color can be chosen from white, amber red, and blue.
*The illumination color cannot be changed.
Defi-Link ADVANCE SYSTEM is the next generation system that adopted the interactive communication.
Defi-Link ADVANCE Control Unit is necessary to operate ADVANCE BF Meters
PRODUCT FEATURES
Feature Note
Interactive communication advanced system is implemented.
Flat glass and precise graduation scale give more needle accuracy and high visibility.
Gauges can be controlled from distance with the included switch unit.
Opening and closing modes can be selected from 2 variations.
The installation of additional gauges is easy. Just connect it with theother two gauges and attach the wire to Advance Control Unit.
The light-emitting gauge always provides clear visibility with high contrast.(The brightness is 200% compared to existing models.)
The needle pointer driven by original stepping motor has a smooth instantaneous response to rapid acceleration of high performance vehicles.
Brightness can be adjusted by selecting from five levels for daytime and nighttime separately.(nighttime dimming cancellation function is available.)
The microcontroller calibrates up to 270 degree angle in 3027 - 4600 segments (0.088°- 0.059°), and provides accurate vehicle information.
Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit and serial communication errors.
Warning by buzzer sound when the warning LED is on (buzzer sound can be turned on / off).
Peak value and warning value during driving are stored. Driving data can be stored and replayed up to 3 minutes.
A mounting bracket and meter cup are provided with this product. Regular position bezel is not provided, but it can be purchased as an additial part.
With both fuel pressure gauge and turbo installed, differential pressure can be monitored on the fuel pressure gauge screen.
Defi boost $299+10 shipped
defi oil temp $275=$10 shipped
defi water temp $275+10 shipped
defi oil press $335+10 shipped
defi fuel press $335+10 shipped
defi ext temp $335+10 shipped
defi controller advance $225+10 shipped
(please notice old defi bf cannot be use)
