cjmotor
TOMEI OUTLET COMPONENT PIPE FOR MITSIBISHI EVO X 4B11 -COMING NEXT WEEK
OUTLET COMPONENT  EXPREME for 4B11 EVOX
Larger, Optimized Flow
for More Power
4b11_outletcomponent_image.jpg outletcomponent_kit.jpg KIT CONTENTS spacer_25-25.gif OUTLET COMPONENT FLANGE NUT M12 * P=1.25 GASKET (TURBO SIDE) STICKER (EXPREME) GASKET (CATALYZER) BOLT SMOOTH PASTE CLAMP BAND INSTALLATION MANUAL BLIND PLUG STICKER (TOMEI) COPPER WASHER WARRANTY CARD STUD BOLT M10-40 P=1.25 (THREAD 12/26)
PART NUMBER : 433001  SELLING $649+SHIPPING
spacer_25-25.gif After testing a variety of shapes and pipe diameters here at Tomei R&D Lab, we found the optimum tuning point for the best performance balance. This design will extract the full capabilities from the EVO 10 4B11 engine. The design also retains the original layout to help with the ease of installation and compatibility for other exhaust parts. ■ WIDE MOUTH spacer_25-25.gifwidemouth_outlet.jpgspacer_25-25.gif The smooth flowing design, without steps from the turbocharger. Manufactured with the lost wax process, combines both strength and beauty. spacer_25-25.gif ■ 3 INCH PIPE spacer_25-25.gif 3inch_pipe.jpg spacer_25-25.gif After numerous tests, the 3 inches (76.3mm) greatly increases both power and torque.
■ TORQUE & POWER
4b11_outletcomponent_gluf-e.gif spacer_25-25.gif Wide mouth & 3 inch piping. Achieve large power & torque gains over stock. spacer_25-25.gif00.jpgspacer_25-25.gif02.jpgspacer_25-25.gif Direct bolt on that retains the original stock layout. 03.jpgspacer_25-25.gif Lost Wax casting process for maximum durability,
precision without welds. spacer_25-25.gif04.jpgspacer_25-25.gif Larger in size and diameter, smooth
without any steps. 05.jpgspacer_25-25.gif The larger curve design makes it possible
for a much larger capacity. spacer_25-25.gif06.jpgspacer_25-25.gif Improved efficiency through with
MATERIAL
PIPE DIAMETER (Φ)
PIPE LENGTH (mm)
FLANGE LENGTH (mm)
WEIGHT (kg)
TOMEI
SUS304
76.3
1.5
13-12
4.8
(With Accessories)
STOCK
STEEL
64.5
1.5
12-12
5.2
spacer_25-25.gif GOOD DESIGN FOR TOOLS O2 SENSOR BOSS FOR AFR GAUGES 07.jpg The wide mouth was designed to be easy to install with the general common work tools. 08.jpg The mouting boss is an M18, which makes it easy to fit the AFR sensor. Comes with a blind plug to seal the hole when not in use. FLEXIBLE PIPE DESIGN MIKALOR HIGH GRADE BANDS 09.jpg Easy to install with minimal risks to cracking the stainless steel exhaust manifolds from vibrations. 10.jpg The Supra Bands made by MIKALOR is what we have chosen to use, since they maintain the strongest torque to secure a proper strong connection. We also used Nejiname bolts
