JMR 24 0 Posted February 16, 2012 Just put a GT28 on my ca18det and am having difficulty with a oil return line. Is there a specific oil return line i need to use or an after market one i need to buy, thanks all Share this post Link to post Share on other sites
Datsun240z 0 Posted February 16, 2012 Depending on the return you can sometimes re-drill the holes to make them line up or make one from scratch with flat bar and tube. If not you can buy them pretty readily around the place. Try MTQ or ATS. Share this post Link to post Share on other sites
brent47 55 Posted February 16, 2012 I got an S15 oil drain brand new when i put a 2860rs on my CA bluey, worked a treat Share this post Link to post Share on other sites
brent47 55 Posted February 16, 2012 Or yer I bought high temp handling rubber hose, only needed 7-8cm's and lined it up and hose clamped on each end. It's not under mad pressure or anything, just has to be heat tolerant. Share this post Link to post Share on other sites
S13 Track Hack 2 Posted February 18, 2012 yeah i just used a piece of silicone hose that had a 90 degree bend in it. had no problems with it Share this post Link to post Share on other sites
