LinkAuto
Motul Gear, Transmission and Hydraulic oils
There are currently three ranges of gear oils available from Motul, grouped into their base quality.
The 100% synthetic “Motul Gear” range comes in three variants, for different applications.
34300-1L.png?1302004497
Gear Competition –
  • Offering the highest protection against wear
  • Ability to resist shock
  • High heat range to resist breakdown in harsh conditions such as track racing
  • Proven by its use in the Mugen Le Mans 24Hr race car.
34210-1L.png?1302004363
Gear 300LS
  • For high performance street use, with the ability to be used for occasional Motorsport events
  • Best of both worlds – High protection and shock resistance, without the need for resistance against extreme conditions
34200-1L.png?1302004366
Gear 300 –
  • Suitable for every day driving in high performance vehicles
  • Offers the highest standard in protection of the mechanical components
  • Long life
Also available:
  • GEAR FF LSD Type 2 (No picture at the moment)
46262-1L.png?1328710726
  • Nismo Competition Oil
The Synthetic range, or “Technosyntheses” range –
  • Suitable for use in most cars
  • Best used in your every day car
  • Offers high protection and long life
  • Affordable cost for every day use
MOTYLGEAR_75W80_1L.JPG?1302703417
Motyl Gear (75W90 & 75W80)
  • For a better resistance at high temperature and longer life
  • Suitable for all manual transmissions
  • Synchronised or non synchronised gearboxes
45600-1L.png?1302005171
Multi ATF
  • Suitable for all automatic transmissions except CVT transmissions.
  • Long life
Also available:
26900-2L.png?1302005206
  • Dexron III
35100-1L.png?1302004927
  • Gearbox 80w-90
Finally there is the Mineral range of gear oils – While technology advances to create superior oils for use in modern cars, they are often unsuitable for older engines and drive train components found in classic cars.
This is because of the different materials used in older components, which can have unwanted reactions when in contact with additives contained in modern oils.
The Motul mineral gear oils available are:
18000-2L.png?1302004930
90PA
  • Mineral lubricant specially formulated for limited-slip differentials (LSD)
  • Suitable for racing cars
  • Passenger cars
  • 4WD
  • Suits heavy vehicles such as Forestry and Construction vehicles
Gear%20Oil%20SAE%2090.png?1302690702
Gear Oil90
  • Mineral lubricant for lightly loaded mechanical transmission
  • Manual gearboxes and differentials
  • Fully compatible with copper and bronze alloys
  • Specially recommended for vintage or classic cars.
35000-2L.png?1302004527
GearV
  • Castor oil based lubricant for screw and wheel rear differentials or crown made of bronze alloys
  • Lubricant for lightly loaded manual transmissions and differentials
There are some new products set for release, such as DEXRON VI and CVT Specific. More news on that when it happens.
just put gear300 in my s15 gearbox, its so quiet now! quality product fo sho
though i only put 1 litre, hope its enough
You mean you put in ONE litre in total??
Take a look at this page for reference to oil quantities
http://www.nissansil...howtopic=499814
There is a specified amount, but you'll never drain out 100% of the oil fluid, so filling until it spills out of the filler hole is equivalent to putting in a measured amount.
