FD_DRIFT
Power FC djetro
Hi,
Im currently fitting an s15 jdm pfc d jetro and it won't start :/ it sounds like the fuel pump is being powered up but makes a funny ticking noise instead of the normal whirring noise the hand controller starts up also but just cranks, The car is an s13 with a jdm s15 engine loom and ecu the stock s15 ecu runs the car fine.. Would anyone have an idea what it could be?
Chris
What did u do about the map sensor and air temp sensor ?
It's all jdm ecu,loom, motor, pfc. I wired up the ait sensor as per the pfc manual instructs to add the plug to pin 26 and join the ground to pin 21, and map sensor wire plugged into the side of the pfc.
The hand controller just sits in the apexi logo part, and doesn't come out of it
The egi pump relay also clicks off its rocker when ign is on, I checked the wires at the relay the earth wire on channel #3 flickers like crazy doesn't stay constant
Edited by FD_DRIFT
