tumbleweed
upper cylinder head cleaner
Subaru upper cylinder head cleaner. Most of you would know the stuff. Obviously safe to use in turbo models.would you use it on your car ? It removes carbon and stuff but these deposits that the cleaner removes would end up going through the turbo before going out the exhaust , could this cause damage? Thoughts?
I see where your going there......... and nah would it not burn in the combustion chamber on its way through ?
Have used it on both my cars and I never got the big cloud of smoke like you see on youtube when searching sea foam of upper cylinder etc
I have used it on holdens fords Toyotas and subis only the subis seem to really smoke. was just thinking about it this morning , I can't see any difference using it on my Silvia , if it works on turbo subis. I rate it very highly , just seeing if anyone else has used it on nissans etc.
the best cyln head cleaner is running your car on e85
keeps engines sparking clean!
Distinct lack if corn booze out here in the sticks :-( thought about methanol mix but shit ain't cheap. You used the cylinder head cleaner Simon?
Really good, used it a couple times on my car and had no problems.
The Subaru stuff is highly regarded as the best you can get as well.
i use the wolfchester stuff on most of my cars. works wonders.
also helps to smoke out the neighbours.
(spraypainter with no booth and inbred daughters and inbred kids running everywhere)
been wanting to use this stuff. How do you go about application?
tells you how to use it on the can, i use it a bit at work, has been the miracle cure on more than one occasion, motorcraft stuff is exactly the same as subaru stuff too, both are made by bars
I've used it, amazing stuff, the lOcal VW dealer sells it
