TAARK
Genuine Nissan Parts! + NISMO Parts!
If you can't find the part your looking for feel free to PM me and we can order it in!
All parts are in stock and ready to ship! (unless stated)
Check out our FEEDBACK here: (click on profile feed) Link
Click Categories:
NISMO
CA18 PARTS
RB PARTS
SR20 PARTS
DRIVETRAIN
SR20VE PARTS
BODY PARTS
INTERIOR PARTS
NISMO PARTS
Nismo Engine & Gearbox Mounts
Description:
Nismo mounts are 30-40% stiffer which makes motor shake less at idle and the Nismo transmission mount provides precise shifting at high rpm from reduced motor/transmission movement.
Application: S13/180sx, S14, S15
Price: $350 per set
Or buy separately
$130.00 LH Engine Mount
$130.00 RH Engine Mount
$120.00 Gearbox Mount
Nismo Aluminum Gear Knobs
Description:
Genuine Nismo gear knob. CNC machined from solid aluminum and anodised.
These will fit any nissan with a 10mm Thread. Most 5spd nissan (S13 S14 180sx etc)
Colours: Black or Chrome
Price: $100.00
Nismo Duracon Gear Knobs
Description:
Colours: Black or White
Prices:
White: $100.00
Black: $80.00
Nismo Radiator Caps
Description:
Nismo radiator caps... Higher holding pressure for better cooling. 0.3Mpa (1.3kg/cm2)
Will suit all Nissans
Price: $65.00
Nismo Oil Caps
Description:
Absolute quality genuine Nismo Oil Cap (Type 1).
Note: Beware of cheap imitations. This is the genuine article not some rip-off copy made from substandard materials.
Application: All Nissans
Price: $95.00
Nismo Thermostats
Description:
Regular thermostat opens at 76 degree C, Nismo thermostat opens at 65 degree C for better cooling. Results in at least 5 degrees C lower at Full throttle acceleration. A must for a modified engine.
Application: All SR20's
Price: $105.00
Nismo Big Clutch Slave Cylinder
Description:
These nismo clutch cylinders have a larger piston to create a softer pedal on those heavy and harsh clutches.
These are direct replacement for the standard ones.
Will suit S13/S14/S15 SR20 & CA18
Price: $200
Nismo Clutch Pivot
Description:
When a sports clutch cover or multi-plate clutch set are used, the stress on the release fork and the release pivot which acts as a fulcrum are also increased. In competitive driving and other high-load situations there is the danger of the release pivot failing.
The Reinforced Release Pivot is manufactured of high-quality chromoly steel, providing a 30% increase in strength compared to the standard carbon steel pivot, reducing the chance of failure due to overload. The use of a flat washer instead of standard spring washer also reduces the chance for the release pivot to become loose and fail due to excessive play.
Application: S13, S14 & S15
Price: $60.00
Nismo Shift Stickers
Description:
Brand new genuine nismo shift stickers. A must have for those with aftermarket shift knobs without shift patterns on them. Keep the police happy!
Price: $5.00 each (out of stock, more in 1 weeks)
5spd & 6spd versions available...
Nismo Exhaust Hangers
Description:
Brand new genuine nismo exhaust hangers. A must have for those with aftermarket exhausts. These are stronger than factory and hold your exhaust firm in place.
Price: $25.00 each
CA18 PARTS
CA18 Exhaust Gaskets
Description:
Ca18 exhaust gaskets. Genuine Nissan.
4 per engine needed.
Price: $12.00 each
CA18 Rocker Cover Gaskets
Description:
Ca18 rocker cover gaskets, if you have oil leaking from your rocker covers then you will need to replace these along with the half moon seals. 2 per engine.
Price: $30.00 each
CA18 Half Moon Rocker Seals
Description:
Ca18 rocker seals, if you have oil leaking from your rocker covers then you will need to replace these along with the main gaskets. 2 per engine.
Price: $9.00 each
CA18 Oil Pump
Description:
Always good to replace your flogged out oil pump when rebuilding your motor...
Price: $200.00
CA18 Oil Pump Gasket
Description:
If your rebuilding or replacing your CA18 oil pump then you will need a new gasket.
Price: $10.00
S13/180sx CA18det Engine Gasket Kit
Description:
Rebuilding your motor? This is a full genuine nissan gasket kit.
Nissan Gasket Maker
Cylinder Head Gasket
Oil Pan Front Gasket
Oil Pan Rear Gasket
Retainer Gasket
Rocker Cover Gasket
Front Cover Gasket
Power Valve Gasket
Intake Manifold Gasket
Exhaust Manifold Gasket
Turbo Charger Outlet Gasket
Turbo Charger Inlet Gasket
Inlet Tube Gasket
Oil Pump Gasket
Connector Gasket
Oil Filter Brkt Gasket
Throttle Chamber Gasket
I.A.A. Unit Gasket
Water Pump Gasket
AAV Valve Gasket
Crankshaft Rear Main Oil Seal
Camshaft Oil Seals
Valve Stem Oil Seals
Crankshaft Front Main Seal
Oil Strainer O-Ring
Price: $260.00 (out of stock, more in 2 weeks)
CA18 Lifter
Description:
Rebuilding a motor or have a collapsed lifter? Then replace them now.
8 Required
Price: $42.65ea
S13/180sx CA18 Timing Kit
Description:
Is your car over 80000km's? Then your timing belt needs to be replaced. This kit comes with everything you need.
Comes with:
1x Timing Belt
1x Water Pump
1x Front Main Seal
2x Camshaft Seals
1x Timing Belt Tensioner
1x Thermostat
1x Timing Belt Idler Pulley
1x Timing Belt Tensioner Spring
1x Water Pump Gasket
Price: $400.00
RB PARTS
RB26 N1 Oil Pump
Description:
Always good to replace your flogged out oil pump when rebuilding your motor... This is the upgraded N1 version
Price: $320.00
RB26 N1 Water Pump
Description:
Always good to replace when rebuilding or having cooling problems. This is the upgraded N1 version.
Price: $325.00
RB25 Oil Pump Gasket
Description:
If your rebuilding or replacing your RB25 oil pump then you will need a new gasket.
Price: $5.00
RB25 Intake Gasket
Description:
If your pulling your RB intake manifold off, then you need one of these... Genuine Nissan.
Price: $35.00
RB25 Plenum Gasket
Description:
Price: $30.00
RB25 Throttle Body Gasket
Description:
Price: $3.50
RB25 Exhaust Gasket
Description:
If your pulling your RB manifold off, then you need one of these... Genuine Nissan.
Price: $60.00
RB20, RB25 & RB26 Rocker Cover Gaskets
Description:
RB rocker cover gaskets, if you have oil leaking from your rocker covers then you will need to replace these along with the half moon seals.
2 per engine.
Price: $20.00
SR20 ENGINE PARTS
2 Bolt Exhaust Gasket
Description:
Replacement exhaust gasket 3"
Price: $12.00
3 Bolt Dump Pipe Gasket
Description:
Replacement exhaust gasket 2.75"
Price: $12.00
S13/S14/S15 SR20 Gasket Kits
Specify when ordering.
Description:
Comes with:
Nissan silicone gasket (orange)
copper oil drain crush washer
stock size headgasket
rear main crankshaft seal
timing chain tensioner gasket
valve stem seals (16)
valve cover gaskets (main and spark plug well gaskets)
front main crankshaft seal
intake manifold collector gasket
intake manifold gasket
exhaust manifold gasket
turbo inlet gasket
turbo outlet gasket
intake inlet tube gasket
oil strainer/pickup o-ring gasket
fuel injector o-rings (4 upper, 4 lower)
cam angle sensor gasket
throttle body gasket
water temp sensor gasket
AAC valve gasket
Oil Line Copper Washers (2)
Water Line Copper Washers (6)
Oil Filler Cap Seal
Turbo Oil Drain Gasket
Price: $250.00
S13 Fuel Tank O-Ring
Description:
If your replacing your fuel pump then you will need one of these. The original ones stretch and never go back into place properly.
Price: $15.00
S14/S15 Fuel Tank O-Ring/Seal
Description:
Price: $20.00
S14/S15 Fuel Tank Lock Ring
Description:
Swapping your fuel pump? These tend to strip and get damaged when removed. Best to have a spare just in case.
Price: $10.00
SR20 Fuel Filter
Description:
Use only the best genuine parts when servicing your pride and joy!
Price: $35.00
Z32 Fuel Filter
Description:
This a Z32 300zx twin turbo fuel filter, they flow more fuel with less restriction.
Price: $35.00
SR20 Injector Insulators
Description:
Replacing your injectors then it's best to replace those old and worn insulators.
Price: $30.00
SR20 Injector O-Rings
Description:
Upgrading you injectors? Then you will need new o-rings to install them!
Price: $21.00
S13 SR20 Fuel Rail
Description:
Need a new fuel rail to make your engine bay look brand new?
Price: $80.00 (out of stock, more in 3 weeks)
S13 Intake Manifold Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan intake gasket.
Price: $17.00
S13 SR20 Collector Gasket
Description:
If your pulling your stock manifold off you will need one of these to put it back on again. These gaskets sit between the 2 halves of the intake manifold.
Price: $10.00
S13 SR20 Manual Throttle Position Sensor (TPS)
Description:
Got a broken TPS, not reading correct voltages then replace it today. This is a common problem on the SR motors.
This sensor is for Manual cars only.
Price: $180.00
S14/S15 SR20 Manual Throttle Position Sensor (TPS)
Description:
Price: $90.00
S14/S15 Intake Manifold Gasket
Description:
Price: $30.00
S14/S15 Collector Gasket
Description:
Price: $15.00
SR20 Intake Bolt
Description:
Pulled your intake manifold off and lost or broken a bolt or just want to replace them? Look no further! Genuine Nissan.
Price: $2.00ea
SR20 Intake Stud
Description:
Pulled your intake manifold off and lost or broken a stud or just want to replace them? Look no further! Genuine Nissan.
Price: $1.60ea
SR20 Intake Nut
Description:
Pulled your intake manifold off and lost or broken a Nut or just want to replace them? Look no further! Genuine Nissan.
Price: $1.50ea
S13 SR20 IACV Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan idle air control valve gasket.
S13 = Price: $10.00
S14/S15 IACV Gasket
Description:
Price: $5.00
S13 SR20 Throttle Body Gasket
Description:
If your pulling your SR intake manifold off, then you need one of these... A genuine nissan throttle body gasket.
Price: $10.00
S14/S15 Throttle Body Gasket
Description:
Price: $5.00
S13/S15 SR20 Igniter
Description:
Replacement igniter for SR20's in S13/S14 cars.
Price: $300.00
Genuine Nissan SR20 Coil Packs for S15
Description:
Is your car miss firing or have you burnt a coil pack out? Then check out these brand new genuine nissan coil packs!
Price: $100.00ea
SR20 Coil Packs for S13/S14
Description:
Price: $105.00ea
S13/180sx SR20 Coil Pack Cover
Description:
Replace that lost, broken or dirty coil pack cover today and make your engine bay look great!
Price: $60.00
SR20 Hydraulic Lifter
Description:
Building a new motor or have a collapsed lifter, then get genuine nissan lifters here!
8 Required
Price: $56.25ea
SR20 Rocker Arm
Description:
Building a new motor or snapped a rocker arm? Then get genuine nissan rocker arms here!
8 Required
Price: $37.00ea
SR20 Intake & Exhaust Valve Stem Seals
Description:
Building a new motor or just need to refresh a head. Get your genuine valve stem seals here!
8 Required of each required
Prices:
Intake: $6.00 each
Exhaust: $6.00 each
Genuine Nissan S15 VCT Unit
Description:
Got a rattle on your VCT SR20 motor that just wont go away? There is a very good chance this part has worn out. Replace it now!
Price: $400.00
Genuine Nissan S15 VCT Solenoid
Description:
Price: $140.00
SR20 Cam Squirters
Description:
Are your oil squirters clogged and not oiling your expensive cam properly? Replace them before you do permanent damage.
Intake Price: $42.50
Exhaust Price: $42.50
SR20 Head Bolts
Description:
These should be replaced every time the head is removed as they stretch. These are genuine Nissan.
10 required
$7.00 each
S13 SR20 Rocker Cover Gasket
Description:
If your rocker cover is leaking... Then replace that gasket! Comes with the spark plug well seals also!
Price: $45.00 (set)
S14/S15 SR20 Rocker Cover Gasket
Description:
Price: $40.00 (set)
S13/S14 SR20 Rocker Cover Studs
Description:
There are 2 sizes available. The outer ones and the center one.
Price:
Outer: $4.20
Inner: $3.00
S13/S14 SR20 Rocker Cover Washer
Description:
Ever lost one of these... Then look no further.
Price: $10.00 each
S15 Outer Rocker Cover Bolt
Description:
Missing or snapped a rocker cover bolt? Then look no further!
12 required
Price: $5.00ea
S13/S14 SR20 Exhaust Stud
Description:
Pulled your manifold off and lost or broken a stud or just want to replace them? Look no further! Genuine Nissan.
8 Required
Price: $10.50ea
S13/S14 SR20 Exhaust Washer
Description:
Pulled your manifold off and lost a washer or just want to replace them? Look no further!
8 Required
Price: $3.40ea
S13/S14 SR20 Exhaust Nut
Description:
Pulled your manifold off and lost or broken a Nut or just want to replace them? Look no further! Genuine Nissan.
8 Required
Price: $2.00ea
S15 SR20 Exhaust Nut
Description:
8 Required
Price: $2.00ea
S15 7 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly and are re-usable. They come standard on the S15 SR20det and will work with any SR20det!
Price: $70.00
S15 3 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly. They will work with any SR20det!
Price: $32.00
SR20 parts continued in the next post…
T28 Turbo Gasket Kit
Description:
All those handy gaskets in one neat little kit!
Comes with:
1x T2 Turbo Gasket
1x T28 Dump Gasket
4x Water Feed Washers
2x Oil Feed Washers
1x Oil Drain Gasket
1x Compressor Inlet Gasket
1x Compressor Outlet Gasket
Price: $70.00
T25 & T28 Manifold -&--#62; Turbo Gasket
Description:
Blown your turbo gasket? Or just need a new one for when you pull it off?
Price: $30.00
T25 Turbo -&--#62; Dump Gasket
Description:
Price: $25.00
T28 Turbo -&--#62; Dump Pipe Gasket
Description:
Price: $20.00
T25 Oil Drain Gasket
Description:
Price: $5.00
T28 Oil Drain Gasket
Description:
Price: $5.00
T25 Metal Oil Drain
Description:
Swapping turbos or got an oil leak? You will need this drain tube.
Price: $20.00
T28 Metal Oil Drain
Description:
Price: $38.50
T28 Rubber Oil Drain
Description:
Swapping turbos or got an oil leak? This rubber hose can perish over time and should be replaced.
Price: $20.00
T25 & T28 Turbo Compressor Inlet Gasket
Description:
Price: $10.00
T25 & T28 Turbo Compressor Outlet Gasket
Description:
Price: $10.00
SR20 Oil Feed Copper Washers
Description:
These should be replaced every time you remove the banjo bolt to ensure you get a good seal. These are the updated version that are joined together so no more dropping and losing them!
Price: $2.00ea
SR20 Water Feed Copper Washers
Description:
Price: $2.00ea (out of stock, more in 3 weeks)
T2 Turbo Locking Tabs
Description:
These bolt onto the turbo when fitting onto the manifold, once the nuts are done up the tabs are folded up to prevent the nuts from rattling loose.
Price: $9.00 each
T2 Manifold Nut
Description:
Lost or Damaged a nut when removing your turbo? New ones are right here. These bolt the turbo to the manifold. Genuine Nissan.
4 Required
Price: $4.50ea
T25 & T28 Manifold Stud
Description:
Lost or Damaged a stud when removing your turbo? New ones are right here. These hold the turbo to the manifold. Genuine Nissan.
4 Required
Price: $5.00ea
T25 Turbo Dump Bolt
Description:
Lost or broken a bolt when pulling your turbo off? You'll need new ones! Genuine Nissan.
3 Required
Price: $4.00ea
T25 Turbo Dump Stud
Description:
Lost or broken a stud when pulling your turbo off? You'll need new ones! Genuine Nissan.
2 Required
Price: $10.70ea
T28 Turbo Dump Bolt
Description:
3 Required
Price: $4.50ea
T28 Turbo Dump Stud
Description:
2 Required
Price: $3.50ea
S13 SR20 Water Pump
Description:
Always good to replace when rebuilding or if your having cooling problems.
Price: $85.00
S14/S15 Water Pump
Description:
Price: $100.00
SR20 Power Steering, Air Conditioner & Alternator Belt
Description:
Genuine nissan fan belts.
Price: $35.00 each (only S15 power steering belts in stock)
SR20 Front Main Seal
Description:
Got oil dripping out from between your engine and harmonic balancer? Then theres a good chance it's this seal! So replace that old leaking front main seal today...
Price: $20.00
SR20 Rear Main Seal
Description:
Got oil dripping out from between your engine and gearbox? Then theres a good chance it's this seal! So replace that old leaking rear main seal today...
Price: $30.00
SR20DET Timing Chain Kits
Need to do your 100k service? Then you need to replace that worn out timing chain...
This kit includes:
Timing Chain
Fixed Chain Guide
Adjustable Chain Guide
S15 Timing Chain Tensioner
Tensioner Gasket
Pivot Bolt
2x Bolts
Price: $350
SR20 Timing Chain
Description:
SR20 Timing chain on it's own. This will fit all SR20de and det motors.
Price: $160.00
SR20 Timing Chain Tensioner
Description:
Got a noisy timing chain or rebuilding your motor, then replace your tensioner now... These are the updated S15 model with longer and finer adjustments!
Price: $100.00
SR20 Timing Chain Tensioner Gasket
Description:
Replacing your timing chain tensioner? Then you will need an new gasket.
Price: $10.00
SR20 Crank Timing Gear
Description:
These should be replaced when replacing your timing chain.
Price: $30.00
SR20 Woodruff Key
Description:
These woodruff keys are what locate the oil drive collar and harmonic balancer onto the crankshaft.
Price: $2.00 each
SR20 Oil Squirter
Description:
Broken an oi squirter? Or just want to replace them in your rebuild?
Includes squirter and the special bolt.
Price: $35.60 ea
SR20 Oil Dip Stick
Description:
Is your dip stick bent, or not sealing properly? Then replace it now!
Price: $30.00
SR20 Dip Stick Tube
Description:
Got a bent or broken dip stick tube? Or just want to put a new one on your new motor? Then grab one now.
Price: $30.00
SR20 Oil Filter Block Seals
Description:
These seals are fitted between the oil filter block and engine block. Required for when fitting an aftermarket item or replacing an old one.
Price: $12.00 each
SR20 Oil Pickup/Strainer
Description:
This is the updated oil pickup the SR20. It has a slotted oil pick up so if the sump gets damaged your engine wont get starved of oil. Always a good idea to replace when rebuilding. It also has the support bracket moved back to prevent the strainer from snapping off.
Price: $40.00
SR20 Oil Pickup Gasket
Description:
If your replacing an oil pump or pickup you will need one of these.
Price: $10.00
SR20 Oil Pump Drive Collar
Description:
Always good to replace these when replacing an oil pump or rebuilding a motor. These tend to to wear out and destroy oil pumps.
Price: $18.00
SR20 Oil Pump o-ring
Description:
These o-rings are fitted between the oil pump and block on all sr20's. A must when replacing the oil pump or building a new motor.
Price: $10.00
SR20 Oil Pumps
Description:
S13 SR20 Price: $280
S14/S15 Price: $300
th_oilpump1Medium.jpg th_oil23Medium.jpg th_oil26Medium.jpg th_oilMedium.jpg
SR20 Oil Drain Plug Crush Washer
Description:
Always replace the drain plug crush washer every time you remove your sump plug to prevent oil leaks.
Price: $3.00
S13 SR20 Oil Filter
Description:
Price: $15.00
S14/S15 SR20 Oil Filter
Description:
Price: $15.00
SR20 Stock Thermostat
Description:
Genuine Nissan thermostats...
Price: $35.00
SR20 Thermostat Housing
Description:
Genuine Nissan thermostat housing...
Price: $45.00
SR20 Bottom Radiator Hose
Description:
Brand new genuine nissan Bottom Radiator Hose for the S13/S14/S15 SR20 motors.
Price: $35.00 (out of stock, more in 3 weeks)
SR20 Top Radiator Hose
Description:
Brand new genuine nissan Top Radiator Hose for the S13/S14/S15 SR20 motors.
Price: $18.00
S13/S14/S15 PCV Valve
Description:
Known for causing problems in SR's... Replace that old valve today...
Price: $30.00
S14/S15 PCV Valve Grommet
Description:
When replacing your PCV valve this should get replaced too as the rubber gets hard and doesn’t seal properly over time.
Price: $12.00
S13/S14/S15 SR20 Temperature Sensors
Description:
SR20's a known for sensor failures leading to all sorts of problems... So replace that old temp sensor now...
We have both S13 and S14/S15 sensors in stock...
S13 Price: $35.00
S14/S15 Price: $40.00
S13/S14/S15 SR20 Gauge Temp Sensor
Description:
If your temperature gauge in your dash has stopped working then this sensor will most likely be your problem.
Price: $25.00
Genuine Nissan O2 Sensors
Description:
Is your fuel economy bad? Then there is a fair chance that your O2 sensor has had it! Good to replace these on a yearly basis.
SR20det "fat" Version $115.00
SR20det "skinny" Version $115.00
CA18det $120.00
S13 SR20de Silver top = "skinny"
S13 SR20det Red top = "skinny"
S13 SR20det Black top = "fat"
S14 SR20det Black top = "fat"
S15 SR20det Black top = "fat"
SR20 Oil Pressure Sensor
Description:
Replacement oil pressure sensor for all SR20's. Genuine Nissan.
Price: $35.00
SR20 N/A Distributor Rotor Button
Description:
Replacement rotor button for SR20 N/A distributor.
Price: $30.00
SR20 Knock Sensor
Description:
This knock sensor will fit all SR20's. Faulty units are a common issue with the SR20 family.
Price: $150.00
DRIVETRAIN PARTS
S14/S15 ABS Hub
Description:
Perfect for that 5 stud conversion or just to replace your wheel bearing. These come with the wheel bearing already pressed in and ready to go.
Price: $220.00ea
2 Required per car
R33 Handbrake Cables
Description:
Perfect for that brake upgrade or just replacement on an R33.
Price: $55.00ea
2 Required per car
S13/S14 SR20 Flywheel Bolts
Description:
Genuine Nissan SR20 Flywheel Bolts. Always good practice to replace these whenever removing the flywheel as the bolts stretch.
8 Required
Price: $4.50 each
S15 SR20 Flywheel Bolts
Description:
8 Required
Price: $3.50 each
S13/S14 5spd Fill Plug
Description:
Stripped your fill plug getting it out? Then you will need a new one.
Price: $5.00
S13/S14 5spd Drain Plug
Description:
Stripped your drain plug getting it out? Then you will need a new one. Has a magnet to catch metal fragments.
Price: $15.00
R200 Diff Shims
Description:
Need a tighter diff, then shim it up…
0.8mm Shim $8.00ea
1.01mm Shim $8.00ea
SR20 5spd Clutch Cover Bolts
Description:
These should be replaced every time you remove the clutch cover as they stretch over time.
9 required
Price: $4.45ea
SR20 5spd Clutch Cover Washers
Description:
These should be replaced every time you remove the clutch cover.
9 required
Price: $4.25ea
S13/S14 5spd Thrust Bearing
Description:
Replacing your clutch or have a whine when you push the clutch in? Then this bearing needs to be replaced.
Price: $50.00
S13/180sx Tailshaft Center Bearing
Description:
Genuine Nissan tailshaft center bearing. These become worn and create vibrations through the drivetrain.
Comes with a new nut and washer.
Price: $160.00
S14/S15 Tailshaft Center Bearing
Description:
Price: $160.00
S13 SR20 Clutch Master
Description:
Is you clutch not working like it should? Or is your clutch master leaking? Then replace it today with a genuine Nissan item.
Price: $100.00
SR20 Clutch Slave
Description:
Is you clutch not working like it should? Or is your clutch slave leaking? Then replace it today with a genuine Nissan item.
Price: $60.00
SR20 Needle Bearing to Replace the Spigot Bush
Description:
These needle bearings replace the stock brass spigot bush in the end of the crank that the gearbox input shaft goes into. The needle bearings last longer and put less stress on the gearbox and are also quieter.
Price: $35.00
SR20 Spigot Bush
Description:
This is the standard spigot bush, if your not keen on the needle bearing version then this is the one for you!
Price: $5.00
SR20 Clutch Fork Pivot Ball
Description:
Snapped one of these? Get a replacement here.
Price: $10.00
S13/S14 5spd Manual Gearbox Gasket
Description:
Replacing your front gearbox seal or bearing? Then you will need this gasket.
Price: $10.00
S13/S14 5spd Manual Front Gearbox Seal
Description:
Got oil leaking in your belhousing and dripping on the ground. Then this could be the seal that’s leaking.
Price: $12.00
S13/S14 5spd Manual Rear Gearbox Seal
Description:
Got oil leaking around your tailshaft dripping on the ground. Then this could be the seal that’s leaking.
Price: $20.00
RB/VG Rear G'box Seal
Description:
Price: $20.00
S13 5spd Shifter Plate Gasket
Description:
If you replacing your shifter or your standard one is leaking then you will need this gasket.
Price: $15.00
S15 6spd Shifter Plate Gasket
Description:
Price: $10.00
S13/180sx Gear Stick Dust Boot
Description:
Doing a manual conversion? Lost yours or have a broken one?
These bolt to the floor pan and seal around the gear stick to prevent oil and dirt out of the cabin...
Price: $75.00
S13-180sx Gear Stick Insulator
Description:
These bolt to the floor pan and seal around the gear stick to block out road and engine noise...
Price: $46.00
S13/180sx Gear Stick Retainer
Description:
These bolt to the floor pan and hold the 2 previous parts in place.
Price: $80.00
S13/S14 Gearbox Shifter Boot
Description:
Does you car smell like gearbox oil? Do you have oil around your shifter? If you do then this is most likely the cause!
Price: $15.00
SR20 Gear Stick Bush
Description:
Brand new and genuine Nissan. Commonly worn part on S13/S14 shifters. Takes some of the sloppiness out of the shifter. Fairly simple to replace.
Price: $7.00
SR20 5spd Clutch Fork Dust Cover
Description:
Replacement clutch fork dust cover.
Price: $20.00
R200 Diff Main Pinion Seal
Description:
Putting a new diff center in or have a leaking diff? This seal is what you need!
Price: $40.00
R200 Diff Carrier Gasket
Description:
Putting a new diff center in? Then you will need a new gasket for re-assembly.
Price: $45.00
S13 Steering Rack Boots
Description:
Replace those old and cracked steering boots now. These come with fixing wire and o-ring.
Price: $35.00 each
S14 Steering Rack Boots
Description:
Replace those old and cracked steering boots now. These come with fixing wire and clamp.
Price:
L/H $32.00 each
R/H $36.00 each
S13 Front Shock Boots
Description:
Replacing your shocks? Or need to pass a roadworthy. Then you will need to replace these.
Price: $32.00 each
S13 Rear Shock Boots
Description:
Price: $72.00 each
Nissan 4 Pot Calliper Rebuild Kit (excludes Brembo)
Description:
Includes everything to do a full calliper rebuild...
Comes with:
Seals
Boots
Clips
Lube
All genuine parts!
Price: $100.00
5 Bolt Half Shaft Bolt
Description:
These are a special bolt used to bolt Nissan half shafts to the diff. Use genuine parts as other bolts here can snap.
10 required
Price: $2.40ea
5 Bolt Half Shaft Washer
Description:
These are a special washer used to bolt Nissan half shafts to the diff. Use genuine parts as other bolts here can cause problems.
10 required
Price: $0.20ea
5 Bolt Half Shaft Nut
Description:
These are a special nut used to bolt Nissan half shafts to the diff. Use genuine parts as other nuts here can cause problems.
10 required
Price: $2.00ea
6 Bolt Half Shaft Bolt
Description:
12 required
Price: $2.40ea
6 Bolt Half Shaft Washer
Description:
12 required
Price: $1.00ea
6 Bolt Half Shaft Nut
Description:
12 required
Price: $2.40ea
R33 Tie Rod Ends
Description:
Are your tie rod ends loose and the ball joint is worn? We have replacements here. Genuine Nissan!
Price: $205.00 (price is for a pair)
S Chassis Tein Tie Rod Ends
Description:
Application: S14 (will fit S13/180sx's & S15’s with tein inner tie rods or S14 tie rods)
Price: $140.00 (price is for a pair)
S Chassis Tein Tie Rods
Description:
Sloppy steering or just after something stronger than factory? Tein has you covered!
Application: S14 (will fit S13/180sx's & S15’s with tein tie rod ends or S14 tie rod ends)
S13/180sx Front Wheel Studs
Description:
Snapped a wheel stud? Then look no further...
Price: $3.00ea
S13/180sx Rear Wheel Studs
Description:
Price: $3.10ea
S14/S15 Rear Wheel Studs
Description:
Price: $3.10ea
SR20VE/SR16VE PARTS
SR20ve P12 Camshafts
Description:
These cams are great for your VE conversion. Perfect for turbo setups!
Price: $720.00
Price includes both intake and exhaust cams.
SR20ve P11 Intake Gasket
Description:
Pulling your intake manifold off or doing a VE conversion? Then you will need one of these.
Price: $30.00
SR20ve P12 Intake Gasket
Description:
Price: $30.00
SR20ve P12 Solenoid Gasket
Description:
Pulling your solenoid off or doing a VE conversion? Then you will need one of these.
Price: $10.00
SR20ve/SR16ve 7 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly and are re-usable. They come standard on the X-Trail SR20vet and will work with any SR20ve or SR16ve!
Price: $60.00
SR20ve/SR16ve Rocker Cover Gasket
Description:
Price: $45.00 (set)
SR20ve/SR16ve Oil Pickup Gasket
Description:
If your replacing an oil pump or doing a VE conversion you will need one of these.
Price: $15.00
SR20ve/SR16ve Oil Pump and Front Cover
Description:
Always good to replace your flogged out oil pump when rebuilding your motor... Or if you are doing a VE conversion you will need one of these.
Price: $290.00
SR20ve CAS
Description:
This is needed when doing a SR20ve or SR16ve head conversion onto a RWD block. Originally from the P12 Primera SR20ve (20v) motor.
Price: $350.00 (out of stock, more in 3 weeks)
BODY PARTS
S13/180sx Door Seals
Description:
Genuine Nissan door seals. This the rubber on the door itself. Replace that old and cracked rubber now.
Price: $122.40 per side (out of stock, more in 3 weeks)
S13/180sx Window Seals
Description:
Genuine Nissan window seals. This the rubber on the body of the car. Stop water leaks by replacing that old and cracked rubber now.
Price: $110.00 per side (out of stock, more in 3 weeks)
180sx Wind Shields/Visors
Description:
Genuine Nissan weather shields. Get that JDM look. Comes with everything needed to install.
Price: $195.00 (out of stock, more in 5 weeks)
S14 Wind Shields/Visors
Description:
Price: $195.00
S13/180sx Door Hinges
Description:
Is your door sagging or not closing properly then this may be your problem. These can get worn out.
Price: $55.00 each (2 per door required)
S13/180sx Door Hinge Pins
Description:
Price: $9.85 each (2 per door required)
S13/180sx Door Hinge Bushes
Description:
Price: $2.10 each (4 per door required)
S15 Bonnet Hinges
Description:
Brand new S15 bonnet hinges. Needed for S15 front conversions.
Price: $80.00 (pair)
S15 Headlight Brackets
Description:
Genuine Nissan S15 headlight brackets. Replace your damaged one or use in a conversion.
Price: $90.00 (pair)
S13/180sx Bonnet Rubber Stoppers
Description:
Missing some rubbers, or removing them for paint and want to replace them with new ones? Then look no further!
Starting from the front:
Center Bonnet Rubber $9.00 each (2 required)
Main Bonnet Rubber $10.00 each (2 required)
Side Bonnet Rubber $7.50 each (2 required)
S13/180sx Door Rubber Stoppers
Description:
Price: $15.00 each (2 per door required)
180sx Boot Rubber Stoppers
Description:
Price: $6.00 each (2 per required)
S13 Boot Rubbers
Description:
Silvia Lightning Badge
Description:
Replace that old badge today...
Price: $45.00
Silvia K's Badge
Description:
Price: $35.00 each (out of stock, more in 3 weeks)
Silvia Badge
Price: $50.00
S13/180sx Door Screen
Description:
Drivers side door screen, this protected your door card and electronics from the elements. Often damaged when swapping speakers or installing alarms etc.
Price: $20.00 each
S13/180sx Door Striker
Description:
Does your door not close properly? Feel loose when closed? Then you may need a new striker.
Price: $30.00ea
S13/180sx Window Washer Hose Clips
Description:
Lost or broken the clips under your bonnet that hold the window washer hose in place? New ones right here.
Price: $3.00 each
S14 Rear Bumper Clips
Description:
Is your rear bar sagging down, lost or broken the clips holding it. We have new ones right here. Genuine Nissan.
Price: $3.00 each
INTERIOR PARTS
S13 Gear Boot
Description:
These are BRAND NEW and GENUINE Nissan gear boots for 180sx and S13 models...
Price: $70.00
Genuine Nissan S14 Stereo Bezels
Description:
These are BRAND NEW and GENUINE Nissan plastic stereo bezels for S14 models...
Price: $110.00
Genuine Nissan S14 Gear Boot
Description:
These are BRAND NEW and GENUINE Nissan gear boots for S14 models... Includes the plastic trim too.
Price: $100.00
Nissan DIN Blanking Plate
Description:
Got a hole in your dash that you want filled, these bolt right in and block off any unwanted DIN slots.
Price: $17.00 each
Nissan DIN Pocket
Description:
Got a hole in your dash that you want turned into a pocket, these bolt right into DIN slots.
Price: $38.00 each
S13/180sx Cluster Cover
Description:
Is your cluster cover scratched and cloudy? Then freshen up your dash now! You wont believe the difference…
Price: $55.00
S14/S15 Fan Speed Resistor
Description:
Is your heater/air con only working on one speed? Then this will most likely be your problem…
Price: $30.00
180sx Parcel Shelf Hanger
Description:
Have you broken one of these, parcel shelf has nothing to hang from? Get a new clip now.
Price: $5.00 each
180sx Parcel Shelf Clip
Description:
Have you broken one of these, parcel shelf has nothing to clip into? Get a new clip now.
Price: $3.00 each
I'm chasing a replacement passenger seat rail for my 180, can you help?
PM Sent
G'day Taark, i'm after a S13/180sx 12v lighter from the centre console. Not the actual lighter but the lighter socket that sits in the console.
Postage to Currans Hill 2567 NSW.
Thanks.
Edited by 6330
Hey taark I'm need a new rubber o ring. It's the one that seals where the fuel pump it bolted into the tank. Do you know the one I'm after? Its for my 180sx.
Hey mate after an s15 throttle cable and the small rubber it mounts into that sits ontop of the intake plenum
Thanks
Thanks
PM Sent
I'm after brake line clips for a s13 if you can get them thanks
PM Sent
Hey Taark, just wondering if you can get a factory side mount intercooler for an rb20?
PM Sent
Hi, I have a diff from a SR20DET S13. Assuming this is R200? If so can I order the 1.01 diff shim please
Guest
