Nick180sx
sil80 na streeter and s13 track car
hi guys and girls
decided to start building a sil80
It all started when i bought a mx5 and decided to turn it into a track car after going to a few track days at winton! A few months later a guy wanted to swap for his sil80 and i said yes since i loved the look of it!
It had a blacktop sr20det in it that was completely stock! The only problem was that it was a auto :(
Since im only 17 i couldn't afford to rego it and pay for insurance so i got my father to :)
week after getting the rego i started building it from ground up
keeping the bottom end stock
Updated from 20/4/13
92 s13 specs
will add pics later when its rolling
Engine: as of 27/01/13
Sr20det redtop
hks2835 0.86 A/R. rear turbine housing
nismo 740 cc injectors
stock plenum
bc cams 264 int 264 ext 12.06mm lift
Adjustable cam gears
z32 afm
nistune ecu
tomei RAS
bc aftermarket valve springs and retainers
Bosch 040
cometic gasket 1.3mm thick
arp stud kit: head studs, exhaust studs, flywheel bolts
3 inch exhaust with rear section straight pipe
Driveline:
s14 box just had a full check over and 5th/reverse selector fork fixed
xtreme 6 puck clutch
lightened flywheel
r33 diff
Suspension:
Cusco coilovers with adjustable chamber tops
Aftermarket tie rods not sure which brand
Cusco camber arms
Brakes
r33 gtst 4 pot front calipers
r33 gtst 2 pot rear calipers
new seals put through all of them
BM44 brake master cylinder
Stock front discs and rear discs
r33 rear hubs
s15 front hubs on s15 uprights and lca's
Wheels:
TE37's sprayed white, will be sprayed black soon
18x9 front 18x9.5 rear
toyo r888 semi slicks
interior is stripped
still need to buy seats etc
And my street car
94 180sx sil80
Engine:
sr20de
pretty much stock except for
pacemaker headers
2.5 inch exhaust system 3 inch tip
Driveline:
5 speed turbo box
heavy duty exedy clutch
stock r180 lsd diff
Suspesion;
Tein superstreet coilovers
Brakes:
stock 1 pot calipers all round
bm34 cylinder
cheaped out on the 5 stud upgrade and bought gktech 4 to 5 stud adapters
Wheels:
18x9 front and rear concave concept wheels +22 offset
stretched bridgestone potenza re001 225/40/18
Interior is stock
Edited by Nick180sx
Exhaust housing is to big on that size turbo for circuit racing
Inlake plenum chamber I would of stuck with the standard item also 90mm throttle body is to big
Exhaust housing is to big on that size turbo for circuit racing Inlake plenum chamber I would of stuck with the standard item also 90mm throttle body is to big
i know ive been trying to find a .64ar rear housing for it and my intercoolers in bay so piping is a lot shorter if that helps
just put a 4.3 diff in it it'll be fine I had one on my sr c35 laurel drift car didn't even have to clutch kick it very often
in a much bigger heavier car there all in by 3,800 rpm
bought r33 5 stud conversion for 350 all up
That is so cheap !!
That is so cheap !!
i know was quite happy
just needed a few new rear studs
also need to buy front hubs
wheres the best place to get them and do i go for s14 or s15 ones?
Edited by Nick180sx
S14 And s15 hubs are the same
Are u going to use the hole knuckle or just the hubs ?
Because if your using the while knuckle u will need the lower control arm as well
I'm using a bm50 on my car and it works perfectly fine and my brakes are massive
Just ask for a 0.64 rear housing, 52 trim.
I did the same thing and it woke the turbo (same turbo) up considerably but I did lose a bit of top end (maybe 10rwk or so). Also cams are a must with this turbo - Tomei 260's would be great but any cams would make it a lot better.
With the brakes, your best changing to the same master that the brakes came off as the standard Silvia master was designed to push oil to single pot rears .
Just ask for a 0.64 rear housing, 52 trim. I did the same thing and it woke the turbo (same turbo) up considerably but I did lose a bit of top end (maybe 10rwk or so). Also cams are a must with this turbo - Tomei 260's would be great but any cams would make it a lot better. With the brakes, your best changing to the same master that the brakes came off as the standard Silvia master was designed to push oil to single pot rears .
well its a bm44 which im pretty sure is the same as the r33 brake master
yeah not really after power
did you notice a difference in spool up?
Edited by Nick180sx
Yes, by about 500rpm which made a massive difference on the track. On the street I found the 0.86 fun, it would bag the tyres hard and didnt cause me any issues in response (just made sure I was in the right gear lol) but on the track it did, which is why it was changed.
ahhh thats mint
just bought bc stage 3 cams 264/272
i would of went 264/264 12.06mm lift
much better suited for that turbo your using
ahhh thats mint
yeah i know but they were only $300
also got the rims today need to get them painted
don't know what color would look best!
any ideas?
Edited by Nick180sx
Thanks man its quite painful but it will get there someday
either that or just white since my calipers are red...
Today i took the sump off to put the extended sump on and found a few metal bits! Im not to sure what they are! any help would be good! black ones are just small rocks
Edited by Nick180sx
mmmm not sure, but you better pull that badboy down
oh f***in hell :( this car wont be running for a while
the other thing i found was a scorch mark in cylinder 1 bore but its not deep and its quite small
few updates
kept rims black
Sprayed calipers blue
head fully rebuilt bc valve springs, shaved, shimmed rocker arms and swapped cams to bc 264 12.06mm intake and exhaust
Pulled engine down nothing wrong with anything all squirters and bores ok
changing timing belt should be finished moday
Upgraded turbo to some BorgWarner unit
Edited by Nick180sx
dam thats a big turbo
only a joke haha yeah its massive ill get a pic next to mine its belongs to my uncles ht putting at like 1500hp at like 15 psi or something
