Slydin
Slydin's N/A 180sx Do not look...too many mods in an N/A, you will be aroused
Hey Everyone, Been on here and JDMST for a while figured I should show you guys my bulid, hopefully you like it was SR20DET Auto then I switched it to SR20DE Manual plus a stack of other shit lol...here goes..........
JUST BEFORE A GOOD CLEAN
CLEAN
READY TO GO IN
SOME DECENT GEARBOX OIL
SR20DET
REMOVED
SR20DE
JUST CHILLIN
AFTER THE SWAP AND A WASH LOVE THIS PICTURE WOULD BE BETTER IF IT WAS TAKEN ON MY GOOD CAMERA NOT MY SHIT PHONE
So I gave the bay a clean plus front strut brace, Alloy Overflow plus new pod filter and custom cover also a air guide just abovethe front bar
Master Cyclinder died so replaced the whole lot
Then I got Gktech Steering wheel
Then made up a knob :P
I got a 2 1/4 exhaust with cat and highflow muffler
Then I got an ignition barrel light :P
March 2012 (Want to do some serious upgrades, was starting to get bored with the car, was still in Year 12 :/ ) :
Got some Front S14 lca's, uprights, hubs and calipers
Then got a BM57 (1 1/16) off Manny
14mm Spacers
Full set of S14 Stockies from a mate
Got the front R32 GTR (Non-Brembo) Calipers and Rotors from Manny
Rear R33 GTST Calipers, Rotors, Hubs and Handbrake Cables off some guy in smithfield
Got my mate to make me my eagle adaprtor plate, just gotta drill the holes
Chucked it all together
Needed A Wheel Alignment
Got a Subframe, removed bushes sanded it down then realised is was bent :/ Pretty much gave up on it :(
Then got a toolbox
Got some Kazama tie rod ends cause my front left one has a fair bit of play in it
Then Yellow-Speed Coilovers came along
This is apparently level -.- massive wheel gap up front, I need to get my guards rolled mainly at the rear so i can sack it all round\
Due to this
Worked really well except we had to wind the coilovers back out because the guard roller was to big to fit in there.
Plus the inside of the tyre had been rubbing as you can see in the image so we raised it up a bit so there was less camber, need to find a set of arms before I can slam it -.-
Thanks to Jordy for letting me use his garage, was going to put it on his hoist but he already had his 1200 on it
Makes working on any car a heap easier
So got my Whiteline Sway Bars, forgot to post the front one ages ago, I won it in a Whiteline comp smile.gif the rear I got off a mate smile.gif
So the Subframe was about to go off for powder coating and this is when I found out it had a slight bend in it plus some more rust... So I forgot about that one, was not going to bother with it anymore.
Got another one, Non-Hicas off a mate so I can piss off this lock bar and Hicas tie rods that way I can run Toe rods, mate sand blasted it for me too smile.gif
Now I have to just get the time to take it down to be coated and decide on a final colour? Birthday is coming up soon, should be getting a full set of SPL arms and bushes.
I got some mudguards off another mate dirt cheap gunna see how they look, not sure if they will suit with the current wheels :S maybe later on when I get some decent wheels.
And I picked up this long block SR20DET came out of a mates S15, so I have two years to learn and build this once I finish off my subframe and adjustable arms and a whole heap of other stuff. Just couldn’t say no for the price...
Then I hunted down another Ca Lip and seen that I could put it on my SR Front bar smile.gif
Resprayed it in a flat back
At Blaises (blaise_mx6) he owns that Z32 300ZX
Then I started on my SPL adventure with some Solid Subframe Bushes
Driving along my temp gauge went off, the temp was higher than usual the inline temp sensor was leaking -.- Pain in the ass so a GKTECH coolant neck spacer is on its way smile.gif Got a hose kit seeing as I need to replace one.
Another night I turn my lights on and one of the cluster globs died frown.gif Have a whole set of leds coming
So resprayed the subframe, primer, blue, more blue then more blue then a heap of clear smile.gif
Smashed out the old bushes, tried to put the new ones in had to use the vice as a press after freezing them :/
SPL bushes are pretty good the only issue I had was the rear two bushes would not clear the Toe Arm brackets so I shaved them down a little
Waiting on Pete from JDM Obsession to get back to me about the SPL arms, can't wait till I get them biggrin.gif
Got a R200 off a mate, having a go shimming it my self pulled it down, more on this later
Thinking about getting a half cage and putting it in with the trim in still like this...
So I got a spare set of stock Rear LCAs of Jason, with this whole build I have tried to do as much bush removal myself with the help of mates but not taking it to a place to get done to keep costs down tongue.gif
Tried to remove these tiny lca bushes was a prick at first but then we figured out a way smile.gif Ball joints were easy
So many ideas, burn it, drill out the center sleeve then burn it, in the end we got a tiny drill bit and drilled down the side got the jig saw in there cut out the center sleeve out and finally with a cold chisel, a 6 pound hammer and a lot of persistence smashed the outer sleeve away too.
Sanded back, primer and some blue, still haven't put any clear on -.-
Got the R200 in the subframe! Never been happier to see a diff chillin in a subframe lol
This thing put me through hell, I had this great idea I should shim it up as my current VLSD is so loose it is depressing in a SR20DE 180sx pretty much peg legging everywhere -.-
So I followed a guide and ripped it down, added an extra 0.80mm shim from Nissan parts no. 38424-40F60 assembled it then went to go drop the center in, that was a c!@t then I bent a shim being rough so I dropped it off at bears in st marys he adjusted the back lash and did me a new shim smile.gif
Sits pretty neat, shame GKTECH haven't made some 180SX/S13 diff covers.
Then that went in :P
So, LCA's have new Super Pro bushes and new OEM Replica Ball joints pressed in, eventually going to get some SPL Rear Knuckle Bushes and Lockout kit ten fit the Lca's all at the same time smile.gif
But for now, my speedo was about 10% out so I purchased a Jaycar build it yourself kit, assembly was easy but install and setup was a pain because I snapped the LED off at 3am trying to install it because I really wanted it done, missus was ready to kill me :/ lol but all is good now smile.gif
Then I wanted more low to fill up the front guards so some mates and I lowered it smile.gif Looks heaps better could go some more in the rear, in the end the front is still going to need a tad larger profile but meh for now plus I got Martin at Ground Zero to tint it, looks sick he did an awesome job at an awesome price, recommend him to everyone biggrin.gif plus spaced the hood tongue.gif
So this is how it stands at the moment, pretty happy biggrin.gif besides the shocking front castor needs another wheel alignment asap bad -.-
So I am about half way saving for rego, thinking about HIDS still dunno if I should go 3000k or 6000k? :S
Got a tad distracted
If you have made it this far thanks for reading, let me know what you think :)
Edited by Slydin
Although you have already solved the problem of the incorrect speedo, there is a dialpot in the cluster which you can adjust (ie when changing diff ratio) to bring it back in. Just check it agains a gps speedo.
Sweet as where abouts on the cluster? :S
are u using kazamma tie rods? did u use lock tight for the nuts?
Looking nice and tidy bud! good start and looks so clean :)
Did you have any issue fitting halfcage in there with the trim still in and do you know if this would be same in s13?
i like what you did with the ignition light... where did you find this?
What shop is that where you got your alighnment?
It's been a while, but going by memory, take the cluster surround off, pop the clear cover off the gauges, and behind the speedo facia, there is a blue square with some numbers surrounding a white (phillips head?) screw, only takes a little turn to adjust it. All I did was left the surround and clear cover off, pushed the cluster back in place, a quick up and down the street, stop, adjust, check again.
nice start mate
Cheers dude
Was using them just did a heap of work replacing worn out parts, The Kazamma Ends were worn within 12 months :/ Which nuts? Locking nuts? or the Inner ends where they go into the rack?
Thanks heaps man :)
I had all the plastics removed then fitted the cage, removed the two rear bars then cut the plastics I just did it without measuring with a jigsaw
The igniotion barrel I got from a 240sx in the States was like $20 you can also get them from a type x but most people want silly prices lol
W.A. was done at Wholesale Suspension
Sweet as good for next time :P
the lock nuts that hold the bump steer adjustment. true shit! did it rust out?
Nuhh mine were nylock nuts so you don't need too :) They didn't rust out they just wore out, has about 3mm play same with the other side :/ :(
Nuhh mine were nylock nuts so you don't need too smile.png They didn't rust out they just wore out, has about 3mm play same with the other side :/ sad.png
true that. do u recommend using the kaz tie ends? cos my mate has a set i might steal off him.
I wouldn't recommend buying them secondhand as they probs are already worn out :/
Nice build mate, How tight is the diff with the 0.8mm shim?
Wanting to shim my diff but not sure if i wanna go 0.8 or 1.1mm.
