TAARK
TAARKS Billet Range! + Koyo Radiators! + Genuine Nissan Parts! + NISMO Parts!
Hi Guy's…
Because we stock so many parts now and to make it easier to find what your after we have split everything up into categories for you.
Just follow the link to the parts your after below, there is a return link to this page at the top of every category page.
Please post in this thread if you have any parts requests or questions as the other threads have been locked.
Enjoy… :D
Taarks Parts
Koyo Radiators
Nismo Parts
SR20ve Parts
SR20 Parts
CA18 Parts
RB Parts
Drivetrain Parts
Body Parts
Interior Parts
New parts since last post below...
Kind Regards,
Taark
PS. Don't forget yo check out the website at: www.taarks.com an our face book page at: www.facebook.com/taarksparts
S15 Center Rocker Cover Bolt
Description:
Missing or snapped a rocker cover bolt? Then look no further!
1 required
Price: $6.00ea
S13/180sx Drivers Door Handle
Description:
Have your door handles faded or broken? Grab a new one today.
Price: $45.00
S13/180sx Passenger Door Handle
Description:
Price: $40.00
S13/S14 Diff Half Shaft Seal
Description:
Putting a new diff center in or have a leaking diff? This seal is what you need!
Price: $10.00
S13/S14/S15 Thrust Bearing Carrier Retainer Clip
Description:
Brand New, Genuine Nissan clutch for retainer clip.
This clip holds the thrust bearing carrier onto the clutch fork.
Price: $6.00
Description:
Brand New, Genuine Nissan thrust bearing carrier.
Price: $35.00
S13/S14/S15 Clutch Fork Retainer Clip
Description:
This clip holds the clutch fork onto the clutch pivot.
Price: $5.00
Description:
Brand new Genuine Nissan clutch fork.
Price: $40.00
Koyo Radiators
Description:
If you have never heard of koyo before, they make some of the very best radiators on the market!
All the koyo's are full aluminum design and are dual core 53mm thick and offer 30% more cooling than stock. They are all complete bolt in replacements, with all fan shrouds retained...
Key Features:
Fully polished to a mirror finish, Provide 20% to 30% more cooling than standard radiators, Handles high revving, high performance motors, Perfect for Turbo Charged, Super Charged & Nitros Oxide equipped engines, Made from aircraft quality aluminum and Heli-arc welded, cores are NOCOLOK-brazed, Koyo Radiator is on the cutting edge of technology and design with Japan's largest automobile manufacture, Custom built OEM fit - All Koyo Radiator cores and tanks are specifically designed and built for each application. No universal fit parts are used.This ensures proper fit, just like your original equipment! Radiators to fit today's most popular import performance cars.
Prices:
S13/180sx SR20 $490.00
S14/S15 SR20 $485.00
TAARKS Stainless Rocker Cover Dome Nuts
Description:
Freshen up your engine bay with these stainless steel dome nuts for your rocker cover.
Price is per nut
13 Required for S13 SR20's
15 Required for S14 SR20's
Price: $1.00 each
th_IMG_0445Large_zpse5e9f5d8.jpg th_S13RockerWashersFitted1Large_zps14f3794b.jpg
TAARKS VE Timing Pin Relocator
Description:
Doing a RWD SR20ve conversion? You will notice that the timing pin is in the wrong spot on the VE oil pump. This little adapter relocated the timing pin to the correct location.
Suitable for standard size pulleys and undersize balancers.
Machined from billet 6061 - T6 aluminum
Anodised black
Comes with:
1x Relocator
2x Stands
2x Stainless Steel M6 Bolts
2x Stainless Steel Washers
2x Stainless Steel Spring Washers
1x Timing Pin
Application: For use on SR20ve & SR16ve oil pumps when using a RWD balancer.
Price: $35.00
th_IMG_0433Large_zps3b7417fc.jpg th_IMG_0435Large_zps69ef4a55.jpg th_IMG_0455_zpsf29236e5.jpg
TAARKS S13/S14 Billet Rocker Cover Washer
Description:
Give your engine bay that fresh look with these billet rocker cover washers.
Simply remove your old rocker washers (keeping the rubber part) and install these over the top.
Machined from billet 6060 - T6 aluminum
Your choice of 4 colours (black, gold, silver or purple)
Price is per washer.
13 required for an S13 motor
15 required for an S14 motor
Application: S13/S14 SR20's
Price: $3.50 each
th_BlackS13RockerWashersLarge_zps48042d93.jpg th_SilverS13RockerWashersLarge_zpsf16e3250.jpg th_PurpleS13RockerWashersLarge_zps1a3e339d.jpg th_GoldS13RockerWashersLarge_zpsc379c74b.jpg th_S13RockerWashersFitted1Large_zps14f3794b.jpg
TAARKS S13 SR20 Water Pump Block Off Plate
Description:
This plate has been designed to replace the water pump allowing the use of and external water pump.
External water pumps off much better cooling and reduces rotational mass on the engine.
Anodised Black
Machined grooves to help sealing
Comes with:
1x Water Pump Block Off Plate
6x Stainless Steel Alen Key Bolts
6x Stainless Steel Spring Washers
Application: S13 Redtop & Blacktop SR20's.
Price: $75.00
th_IMG_0428Large_zps6c36929d.jpg th_IMG_0429Large_zps2d92c64a.jpg th_IMG_0427Large_zps67245f90.jpg
TAARKS S14/S15 SR20 Water Pump Block Off Plate
Description:
Anodised Black
Comes with:
Application: S14/S15 SR20's.
Price: $76.00
th_IMG_0431Large_zps32bb44f0.jpg th_IMG_0432Large_zps6fdde578.jpg th_IMG_0427Large_zps67245f90.jpg
TAARKS S14/S15 Top Feed Injector Collars
Description:
Want to upgrade to top feed injectors? You'll need a set of these.
Machined from 6061 - T6 billet aluminum and anodised gold.
Will fit most 14mm Injectors including the very popular ID1000 and ID2000 injectors.
Price is for a set of 4 collars (includes o-rings)
Application: S14, S15 and P11 SR20's
Price: $40.00
th_S14InjectorCollarsLarge_zps3c40fa91.jpg th_S14InjectorCollarsFittedLarge_zps25a96a2c.jpg
TAARKS Bonnet Risers
Description:
Sick of using a stack of washers to raise your bonnet? Then grab a set of these stylish bonnet risers.
Great for lifting the rear of the bonnet to aid in cooling.
Your choice of 3 colours
Stainless steel hardware included.
Comes with:
4x Bonnet Risers
4x M8x1.25 304 Stainless Steel Bolts
4x M8 304 Stainless Steel Washers
4x M8 304 Stainless Steel Spring Washers
Application: Any car that uses M8x1.25 bolts to hold the bonnet on. (most nissans use these)
Confirmed Fitment: S13, 180sx, S14, S15
Price: $25.00
th_BlackBonnetRisersLarge_zpsd7a98a6c.jpg th_GoldBonnetRisersLarge_zps805bbfc9.jpg th_PurpleBonnetRisersLarge_zps17f4d895.jpg
TAARKS R33 to S13 Handbrake Cable Adapter Plate
Description:
Are you upgrading the brakes on rear of your S13/180sx to skyline brakes?
These adapter plates are required to space the R33 handbrake cables to the right position.
Laser cut from 316 stainless steel.
Application: S13/180sx
Price: $45.00
TAARKS S13 IACV Flange
Description:
Great for that custom intake manifold.
Machined from billet 6061 - T6 aluminium.
Tapped holes ready to mount your IACV to.
Price: $35.00
TAARKS S14/S15/P11/P12 IACV Flange
Description:
Price: $28.00
TAARKS VE Exhaust Flange
Description:
Laser cut 10mm Mild Steel Exhaust Flange.
Great for building a custom exhaust manifold or replacing the flange on your current manifold.
Application: SR20ve & SR16ve
Price: $40.00
TAARKS T2 Turbo Flange
Description:
Laser cut 10mm Mild Steel Turbo Flange.
Application: Manifolds to suit T2 Turbos
Price: $20.00
TAARKS T3 Turbo Flange
Description:
Application: Manifolds to suit T3 Turbos
Price: $21.00
TAARKS S13/180sx Speaker Pods
Description:
Ever wanted to replace the speakers in the doors of your S13/180sx?
These will make that a breeze! Just remove your old speakers and speaker mounts and these bolt right in.
Allows the use of 6.5" or 6" speakers.
Application: S13's & 180sx's
Price: $45.00
Nismo Big Clutch Slave Cylinder
Description:
These nismo clutch cylinders have a larger piston to create a softer pedal on those heavy and harsh clutches.
These are direct replacement for the standard ones.
Application:
ECR33 - RB25DET
HNR32 - RB20DET
HNR33 - RB25DE
HNR34 - RB25DE
BNR32 - RB26DETT (up to Feb 1993)
Price: $185.00
Nismo Clutch Pedal Bracket
Description:
With the use of a reinforced clutch cover, the burden on the bracket, which functions as a fulcrum for the clutch pedal, increases, and there is some danger of the bracket bending or the spot welding coming loose during heavy clutch use, such as in competitive driving. The Reinforced Clutch Pedal Bracket adds additional welding to the standard clutch pedal bracket. Not only is the bracket reinforced but this gives the pedal a more rigid feel, which most people favor.
Application: S13/180sx SR20's
Price: $110.00
180sx Headlight Surrounds
Description:
Nissan 180sx Headlight Surround
Replace your lost, broken or faded surround.
Application: All 180sx's.
2 required per car.
Price: $65.00 each
S13/180sx Steering Column Surround
Description:
Nissan S13/180sx Steering Column Cover.
Includes both upper and lower parts.
Application: All S13's & 180sx's
Price: $90.00
S13/180sx Kick Board Clips
Description:
Lost one of these little guys?
These are the little clips that hold the kick panels in place.
Price: $4.00
S15 Gear Stick Bush
Description:
Brand new and genuine nissan. Commonly worn part on S15 shifters. Takes some of the sloppiness out of the shifter. Fairly simple to replace.
Application: S15 6spd
Price: $5.00
SR20 CAS
Description:
Brand new and genuine nissan CAS for the SR20 RWD motors.
Fix that ignition problem...
Application: S13/180sx, S14, S15 SR20's
Price: $360.00
SR20 CAS O-ring
Description:
Got oil leaking around your CAS? THen replace the o-ring and fix the leak today!
Price: $10.00
S15/P11/P12 SR20 Rocker Cover Washer
Description:
Ever lost one of these... Then look no further.
Price: $7.00 each
You've got a very good range of parts there mate. Really like your billet collection and VE conversion parts. Good prices too, keep it up.
Are you able to source out a s15 starter motor at all??
PM Sent
are you able to get Z32 BMC ABS version? BM-57 the model number
gday taark , how are ya man , just wandering if i could get a quote on a brand new , genuine nissan , clutch slave cylinder to suit r33 skyline gts-t , rb25det , 97 model . if you could pm me details that would be great thanks man
regards anthony
Hi there. Can you ship to Auckland, NZ?
I'm looking for;
Full set of Bonnet Stoppers (centre, main & side) for 1997 180sx.
Door Hinges (top & bottom, driver & passenger) for 1997 180sx.
Door Hinge Pins (top & bottom, driver & passenger) for 1997 180sx.
Door Hinge Bushes (top & bottom, driver & passenger) for 1997 180sx.
Thanks for your time, best regards,
Steve
Guest
