speedie
speed sensor gear colors
i had to replace my speed sonsor recently from my s14 gearbox. I took the usual red colour one out, but the replacement i was given had a blue gear pinion on it. Now my speedo reads about half the speed it should.
I didnt take a photo before it went in, but does anyone know what the blue colour gear pinion might be ?
Different colours refer to the amount of teeth not sure how many to the different colours put the red back in and it should fix your problem
if anyones interested, these are the 2 speed sensors i have. the Red one is from an S13, but im still not sure what the Blue one is from but the cogs are quite different.
s13 red cog and has a wiring before plug
s14 (blue or purple cant remember) no wiring come off it and reads half of a s13 one
Ie put a s14 sensor to s13 cluster it will read half of what you are actually doing
There would have to be something different internally as well; there is only two teeth difference between the gears so that wouldn't account for a 50% reduction in the indicated speed, more like 10%. So there must be a difference in the pluses per revolution sent by the senders as well.
Anyone able to swap the gears between senders To correct small errors
S13s have a pot in the cluster to calibrate speedo
