millerman
Quick bit of help please :)
Mate has an s13 that's in adelaide currently. The compliance plates are no where to be seen and it has no registration either. Is there anyway that's legal to get the car recomplied and or regod in adelaide? Or will it just have to be a tracker?
Cheers appreciate any input
I'm pretty sure you would need to have it sent to regency to have all the engine and body numbers recorded and have new compliance plates made
Do you know if all cars that are imported are given the plates?
All cars have compliance plates and all imports have import plates as extra. With the engine/body numbers (if they haven't been removed) should able to be used to identify the vehicle and new compliance plates should be able to be made.
It has the original vin plates still. But it doesn't have an Australian vin number or import compliance plate :(
No tags, no rego. It's that simple. Neither DoTaRs, nor Nissan will issue you with replacements.
You can thank the clown who thought it was a good idea to remove them and render the car pretty much useless.
Is it possible to recomply again? And get new tags with a new vin
Negative.
You're essentially trying to re-birth the car. Shit will not fly with the authorities.
^^That's pretty much correct. If it doesn't have a compliance plate, it has either come in under pre-89, or as a race/rally import. OP you've got a PM.
