Spec Vo
Thrust bearing
Hi there,
My 180sx recently had its clutch master and slave cylinder replaced as my clutch dropped to the floor.
I went through two slave cylinders due to it popping of the piston, before I finally realized that it the pivot ball that needs replacing.
I was wondering since I would need to drop the gearbox anyways, should I replace the thrust bearing while it dropped?
Yes you also want to look at anything else you can do while in there.
Rear main, extension housing seal, gear stick surround, etc.
